GrillMaster
- Joined
- Jun 5, 2008
- Messages
- 2,484
Building a mild OBDII motor
'85 Block was machined 10 thousandths from deck and cylinder bores, running ross forged flat top pistons. What would my compression look like with some GT40 heads from a (’91 Lightning). Been having some trouble with the compression calculator.
Bore used 4.010
Stroke used 3.5
dome/dish used 4 (gustimate for valve reliefs)
CC 63-66 (used 64)
gasket .039-.041 (used .031 to compensate for .01 off the deck)
deck 0???? 9.503" decked .01 (used 0)
http://www.summitracing.com/expertadviceandnews/calcsandtools/compression-calculator
Bore: (diameter)
4.010
Stroke:
3.5
Cylinder Head Volume:
64
Effective Dome Volume:
Use (-) for Dome and (+) for Dish.
4
Deck Clearance:
0
Compressed Gasket Thickness:
.031
Number of Cylinders:
Compression Ratio : 10.73 : 1
Total Displacement (in.3) : 353.62
Total Displacement cc's : 5797.05
Looks like if I ran a .062 copper gasket it would get me to 10.2:1 which I believe would be ok on the street on pump gas.
Bore used 4.010
Stroke used 3.5
CC 63-66 (used 64)
Bore: (diameter)
4.010
Stroke:
3.5
64
4
Deck Clearance:
0
.031
