ft bronc
I need some help with this one. I've got a stock '73 with factory PS. Rebuilt pump, gear box untouched since it left the factory.
Almost overnight I started getting strange pulsation back through the steering wheel when going around normal street corners (both directions) - no problems at all at freeway speeds. It feels like the pump cutting out, so considering I had about a year and half on a rebuilt pump, I installed another.
No good - exact same problem. And now I noticed that the pump reservoir around the pressure out, the pressure line and the gear box where the lines go in and out are all HOT - too hot to hold your hand on - after only making a couple laps around the block. I'm not sure if they were hot just before changing the pump as I really didn't check.
I'm now assuming it's got something to do with the gear box, but in all my years working on Ford cars & trucks, I've never had a steering box problem (and consequently don't know a whole lot about them as I've never had problems to fix!). Anyone got any ideas?
