Hidden Front Hitch Mount
BruiserOutdoors
I have a winch in a cradle that slides into 2" hitches. Came up with the idea to cut my front bumper for a 2" hitch and hide one behind. Slap a license plate over the hole when not in use. Nobody would know or see it. I would use it to back trailers into tight spots on the property too.
Looking for pictures and ideas of others who have done something similar... anybody mount a hitch to the front of their bronco? Not really sure how i'd fit one in or what it would take.
Sounds like a good idea. Seen it on some Broncos here I think, so with luck some of them are active now and can post up pics of theirs. Or maybe someone has a saved link to some of the discussions about it.
Shouldn't be too difficult as it's one of the few places with at least a little extra room under a Bronco!
Well, unless you're like me and have a radiator crossover tube that would be totally in the way of anything more than a few inches deep.
Good luck.
bronkenn
Bronco Guy
Southeast Ohio
Duff's sells a hitch that bolts to the original frame holes in the rear and I believe the front bumper mount holes are the same as the rear, it would probably bolt right on. Ken
englewoodcowboy
Lick Creek Restorations
As broken stated, Duffs makes one that will go front or rear however it is only rated for 3500# pull. I was looking at an idea that would require a hole cut into the front bumper, you would make a plug to hold a front license plate to cover it when not in use or build a flip down plate bracket. I have not done anything yet but have put some thought into it to make sure it could handle an 8000# pull. Gussets would have to be added that would tie further back on the frame.
GloNDark
I don't see why you couldn't mount a hitch in the front. I managed to put my entire winch behind the bumper/under the front grill. So there is room there.
I thought hard about doing a hitch in the front of my bronco for the winch and in the end I decided to permanently mount it after seeing a buddies cradle winch mount bend with a slightly off center pull.
BruiserOutdoors
BruiserOutdoors
I like the look of a factory bumper and dont want to drive around the extra weight of a winch everyday as I plan to make this my daily driver someday. I would like to bring a winch with me on my offroad adventures, just as a piece of mind!
Thanks for all the great feedback already
blubuckaroo
Grease Monkey
Ridgefield WA
It looks to me like you would be able to fabricate a hybrid between these two hitches. You could use the frame end mounts like the Duffy hitch, and mount the receiver in the center. In fact, you should be able to cut and modify the Duffy hitch.
The only problem I see is the receiver won't be very deep depending on which gas tank you have.
JSBX
Toms Bronco has a class 3 receiver hitch for the rear but it should work on the front. I have one on the rear of my Bronco.
No Hay
I had this done to mine. Turned out great.
COBlu77
Arvada, CO
Here you go.
No Hay
EXACTLY how I imagined doing it. Nicely done.... How'd you mount it to the frame or is it all custom?
Looks similar to COBlu77 pics. Easy project if you can weld. I can not. I had Robert Warke (Crazy Bronco Man) with CBM Performance in Oregon City do mine with other misc work. Check out his work, propane powered beast and videos. He is a true fan.
BruiserOutdoors
BruiserOutdoors
I've seen his rig as well as some others he has worked on... outstanding skills. I've also seen some videos and can understand where he gets his name!
