ntsqd
heratic car camper
I used to be on an email list of guys who were using the eec-IV on all sorts of different engines and sometimes for odd-ball uses. The info is out there somewhere to make it work on just about anything. The key is how deep a dive into that sort of thing do you want to do?
I'd be much more inclined to use the SEFI hardware with an aftermarket ECU than I would be to go backwards to a wet flow intake manifold. Not sure how much support you'll get in doing so, might be that you're going to have to learn how to start from scratch with that ECU's programming. If there's a EFI tuner in your area it might be good to find out what their preferred ECU choice is and investigate those. Ultimately you're likely going to need some time on a chassis dyno to fine-tune it. It is a big chunk to bite off, but the results will be worthwhile and battling Holley's dumb decisions doesn't sound like the results are worth the trouble.
