I have searched thru the forum as much as I can, with not much luck. I have a 74 bronco, 302, mild cam. I installed a holley sniper kit. I am a competent mechanic and I have checked all the usual suspect items. Followed all the instructions to the letter. The truck started fine after install, and ran down the road ok. After some time, the truck will not start after it comes to operating temperature. We can hear the initial fuel spray into the body, but it appears that its not enough to start the engine while hot. No matter what I do, it will not start. It appears that its a tuning issue. I have tried several different settings to get it going, no luck. I tried holley tech support, no answer and put on hold for hours. Can anyone share their experiences with this type of setup?
