I took out the thermostat due to being in Hawaii but not sure if that had an effect.
Well I would put one back in, at whatever temp they recommend (probably 180-195 range) or they may void any warranty you have. You literally can do damage to an engine that never gets up to running temp. Of course, yours obviously gets up to running temp, but removing the thermostat is just a Band-Aid for other issues and does not let it warm up efficiently or effectively. Keeps both carbs and EFI running rich sometimes too.
How quickly does yours come up to temperature?
I can't argue with success, so if you still come up to temp quickly you're likely not harming anything. Just that it "can" do bad things and is not needed when all else is working properly.
If all is working properly, with the right equipment a temp range of 195-205 is right in the sweet spot in fact. And for the rest of us it also makes the heaters work great!
Likely your idea of "turning on the heater" though, is removing the top and running out in the sun!;D
Just to be sure I have the timeline correct here though, when exactly did you remove the thermostat? Before/after/during the Hyperspark swap?
And are you letting the computer control timing, or is the ignition on standard mechanical and vacuum advance?
