Holley sniper question
dgbronc
Bainbridge, GA
You guys that are using the system are you running internal or external pump and if external which pump and where are you mounting it. Pics if possible.
bckmn1
Phoenix
I run the external pump that Holley sells with the kit. I mounted it as far back as I could on the drivers side frame rail.
External for all the projects. Not that internal is bad, but at times it wasn't an option with a new tank, or would require replacing good existing tanks, or a fair bit of money for adaptor pieces.
There are things to watch for with external. Mounting, priming, pre-filter (inline OR pickup sock), baffeling or accumulator, proper return line (not letting the return waterfall back into the pool of fuel).
There are so many ways of doing it. Both internal and external. From buy it and install to a lot of fab work. Budget to budget busting.
LSUpete
External:
Summit fuel pump: SUM-250111 (Gets awesome reviews)
Dewhel Fuel pump billet bracket: www.amazon.com/gp/product/B00VRKQQS2/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1[/url]
AN8 to Male AN6 Flare Reducer: www.amazon.com/gp/product/B01NCLEW2O/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1[/url]
O-Ring Boss/ORB to AN Flair Fitting Adapter - 10AN ORB to 6AN: Bought through 385freaks.com
Fuelab In-Line Fuel Filter - 10 micron paper / 6AN: Bought through americanmuscle.com It's a paper cartridge filter that can be replaced.
D
dgbronc
Bainbridge, GA
Thanks guys having a little problem with sniper kit and looking at way pump was installed. Holley says mount below tank and mine is high on frame rail also above tank and just wondering if this could be part of the problem.
Thanks again
Once the pump has a prime there won't be an issue. Electric fuel pumps can pull fuel, but many can't pull air. I've run an electric fuel pump mounted at the headlight and at the master cylinder at different times, they did fine.
LSUpete
Thanks again
I've run mine on the frame rail for 10 years with absolutely no issues. I would never consider mounting the fuel pump BELOW the frame rail....where anything could damage it.
Devo73
I've had mine on the driverside framerail for four years now, runs great. I think the main thing is to keep the pump as close to the tank as possible, if they gotta pull fuel they don't like to pull it very far
Sent from my Pixel 3 using Tapatalk
