I‘m looking for help from anyone that has installed the Terminator X ECM in their Bronco (with Coyote, F150 motor, etc).
All startup procedures are done and all sensors are checking out correctly. When I crank, I’m getting fuel but no spark. I pulled the plug to see if there was a spark and there’s not.
I’m looking for help. My opinion is that it has to do with the way the ford ignition works. When you turn the key, several “switch powered” connections turn off. If that is happening to the feed to the coil pack, I won‘t have power AKA spark. That’s what I’m thinking but not sure.
Anyone have any similar issues when you hooked the system up?
Any contrarian Views?
