hot floor fixes
Boatsw
East Texas
What are some things, some of you have done..and what seemed to work the best. I know the bronco places sale the "sheild stuff" for under carpet, does it work?
Any ideas
airman
If you want to know what it would be like get a newspaper and put it under a rubber floormat.
76 explorer
oklahoma city
my line-x helped a bunch. it helped keep the heat in in the winter and helped keep the floors from getting as hot during the summer. before the line-x i couldnt touch the floor with my fingers for very long (even in the winter) afterwards i can hold my fingers on the floorboard as long as i want. while its still warm its not even close to being as hot as it was. i dont remember what it cost but it was in the 300 - 400 dollar range. plus now i can use a pwer washer to clean up inside after a wheeling trip.
76 explorer
oklahoma city
the bronco is still loud but what do ya expect with flowmaster original 40s and turndowns ;D i will say however it is MUCH quieter in the cab if the top is on now than it was before the line-x. ive had the line-x in for 4 to 6 months now and i like it so much id do it again if i had the chance.
Raskew
Vancouver, B.C.
Dyna mat is pretty expensive. If your looking for a less expensive option, I used foil duct insulation. You can pick it up at any Home Depot or Hardware store. It works great, to keep the heat out and acts as a carpet underpadding.
Rick
Best fix I did was to put in a carpet kit. Came with the jute pad undernieth. Helped so much with sound and heat. Before it was uncomfortable with shoes on, now you can have bare feet.
Now I want to do something about the roof
B
Boatsw
East Texas
Thanks for all the ideas, since mine is very stock uncut and about 90% on road, D/D I am leaning towards the carpet. Maybe thru out, I was going to carpet the front, and Linex the back, but now.....
Anyway thanks
tbruz
I assume from your name that your rig is a 1976. Depending how stock your exhaust is the basic 1976 exhaust system came with a metal heat shield that mounted on the frame and went between the muffler and the floorboards, about 20 inches long and curved like the stock muffler...can be found on ebay.
TonyB
nvrstuk
PNW
Heat
For short fixes, carpet with jute backing or dynomax works fine. If you're on the trail for hours and hours or highway cruising for the same, you need to keep the heat from getting TO the sheetmetal floor if you want to keep your feet from burning! The heat WILL work it's way thru the carpet/pad/dynomax/whatever. Best way to reduce EB floor heat is: body lift, sheetmetal barrier, distance between heat source and body sheetmetal or a reflective type barrier between the stock sheetmetal and the heat source.
I've got ceramic coated headers, carpet with padding, 2" bodylift, and a alum waterproof reflective fiber "fabric". Much better heat control than stock.
A/C works fine too I'm told! :)
