Hot Floor
Kevin2015
Dallas, TX
I am new to Bronco ownership, love you guys and this site. Thank you.
I went for a joy ride locally, not highway, mostly 35 mph, maybe 25 minutes. When I got back home, I noticed the floor behind the drivers seat was really hot. Any thoughts on this. Didn't seem "normal"
I have metal floors, not carpet. Fresh coat of black paint on the underside and blue on the top side. No insulation that I am aware of.
Millercorey
Totally normal, but easy to see how someone used to driving in more modern cars would get alarmed. You’re riding around on a cookie sheet with nothing to shield you from engine/exhaust parts of a car that get 200+ degrees.
While I love the rugged simplicity of no carpet, I just couldn’t survive in Texas and actually drive the vehicle with any enjoyment. Lizard skin + insulation + carpet for me.
904Bronco
San Martin, CA
Just guessing that you might need some heat shielding on your exhaust underneath... Dual exhaust? Same on the passenger side?
sykanr0ng
The most effective place for the heat shielding and insulation will be under the floor, keeping the metal of the floor from absorbing the heat.
K
Kevin2015
Dallas, TX
Thanks guys.
Yes dual exhaust and hot on both sides. Appreciate the advice. I'll have to save up for the next step.
Apogee
Tangent, OR
I'm digging the cookie sheet analogy...I'm the cookie! As for heat shielding, there have a few decent threads about it in the past couple of months, so you might do some searching to see what others have done to combat the same issues.
KeithKinPhx
Just put the DEI Floor and Tunnel heat shield kit on. Engine not in yet so I can't tell you how much better. Also did the Lizardskin.
Congrats on the new rig.
ep67bro
Bronco Junky
Easton, MD
Normal. You are in a tin can with no insulation and a bunch of heat trying to rise up. Have fun if you get stuck in traffic with the top down and no breeze! Had that happen to me once and I thought my shoes were going to melt!
forrest36
At OCBR in 2016 I had a friend riding shotgun and the sole of one of his shoes did melt off.
blubuckaroo
Grease Monkey
Ridgefield WA
The best thing to do would be to shield the exhaust.
My '77 came with a complete exhaust shield over the entire length of the catalytic converter and muffler.
Most newer SUVs and vans have this. Try a pick yard. You should be able to find something that works.
904Bronco
San Martin, CA
blubuckaroo
Grease Monkey
Ridgefield WA
I don't think it's a good idea to wrap the components. The heat needs to escape. When I posted about a heat shield, I was referring to a shield between mounted with an air gap between the exhaust component and the shield, and between the shield and car body. It can be mounted to either the exhaust component or the body.
Here's an example...
jmangi62
Yea that's a normal thing to feel warm on the sheetmetal, love the "cookie sheet" analogy lol. But its accurate. I have all new metal with bedliner and padding with carpet on top, underneath its just "Rust Bullet" similar to por, and a couple coats black automotive enamel so we'll see this summer how this holds up. My setup should get pretty warm with the hedman long tubes and full length dual exhaust with cherry bombs. Just my .02, good luck. ;)
A Flowmaster will probably rust out the bottom even before any accelerated wear will happen under the jacket!%)
But yeah, not a bad idea maybe to add some steel spacers between the pad and the body of the muffler to let air flow around it to some extent.
That way you can still take advantage of the nice kits with clamps, but not suffer the effects that sometimes come with insulating exhaust. I don't know if a sheet like this, laying over just half the muffler is going to be as bad as a full wrap, but it's probably more of an issue up at the headers than back at the muffler that doesn't get near as hot. But moisture will find a way whenever there's heat and cold.
Time will tell.
Good argument for stainless everywhere?
904Bronco
San Martin, CA
Given that I just finished a 2.5 yr frame off restoration I was not planning on drilling any holes into my floor/frame/rig.
The wrap was relatively painless, reduced the heat from the floor and under liner.
Maybe it will retain the heat inside the flowmaster muffler, maybe it will keep condensation from forming and rotting out the inside...
Ideally, your suggestion would be a better route, but I had space limitations and this worked for me.
That is truly the best thing about this site, everyone chimes in with experience and solutions, and the Bronco Owner gets to choose what will work for them, given their own situation.
Doug
