maxellfullmoon
- Jul 6, 2010
- 63
About to go topless and doorless. What are some ideas for security? All I have now is a kill switch.
Heard of a guy who attached a really bright strobe lights and a giant horn to his brake pedal. When it was on, if someone drove off in it, it would make a lot of noise and flashing lights whenever they hit the brakes.
got EFI? if so trip ya fuel switch.
Your right, and without a way to lock the hood makes the alarm and a kill switch to the distributor about useless.Alarms dont work unless your the one who hears it. Years ago when every body had a alarm they went off so often nobody paid any attention to them!
Id say just dont leave anything of value in the truck! Even with a top and doors on nothing is safe. If your gona worry about your truck everytime you drive it someware then its best not to drive it!
You could unhook the battery, put a fuel shutoff switch, hook up a switch that would disable the starter and instead sound the horn when the key is turned.
Most important thing said is to make sure you have a stated amount insurace policy.
Twin sticks + Lock Hubs + Front in low/rear in high = Grenade t-case but you still have the truck
put the coil wire in ya pocket, how many walk around with one in theirs?
MANY years ago at a street race, one of the cars in the line up had a bad coil wire, another good samaritan gave his up in good spirit to not spoil the moment....cars raced off, spectators in tow back to the meeting spot to divy up. Wiley Trooper showed up after the escape to one dead car sitting there with no coil wire. Trooper told car owner make it go and I'll say there was no body left by the time I showed. Genious pulled off one of the 8 other coil wires and pulled away on 7 cylinders!!!!!!
