Securing Bronco to Trailer
helo-mech
helo-mech
I tried to rent a uhaul trailer once to haul a Bronco, and once I said "Bronco" they refused to rent one, said Broncos were too big for their trailers. I tried to get through their head that it weighs less than a ford explorer but if it aint' in their computer it aint happening. So I went down the street and bought a trailer.
I've noticed a couple of people mention this so I thought I would let everyone know how my experience with Penske went.
I tried to reserve the hauler online and the computer said NOPE!!!! I called the 1-800 number and spoke to a supervisor. I explained that it was an EB and I would appreciate if he would do some research to see that my Bronco was well within their acceptable limits. While I was on the phone with him, he looked it up, verified that the system was wrong, called his web department and notified them of the issue and the change needed, called the local rep and informed them that I would be allowed to use the car hauler and sent me an email to document it all.
I have not gone back yet to see if the web selection has changed, but I intend to do so after things slow down a little. I also plan to write a letter to Penske because the level of service I have received and the condition of the 27' International Diesel moving truck have been outstanding.
IMO they are at a different level than U-Haul. I have only rented from U-Haul once, but I have helped many a friend move and I have never been impressed with their equipment. When I was wee lad I traveled to Amarillo TX to change an engine on a helicopter that had a mishap during a cross country trip. The engine, myself and my Quality Assurance guy got there on a CG fixed winged aircraft. When we were done, the helo and crew flew off into the morning light and left us there thinking "what now?" The fixed wing bird was off with more important missions and not coming back. The QA guy, much my senior, said "we're gonna rent a truck and drive this POS engine back to overhaul." I figured U-Haul. He went straight to Penske saying they had the better equipment and service. He was right and I have never looked back.
I've done it both ways but I prefer to tie to the frame instead of the axles. I don't like the body roll going on while travelling.
I chain over the springs by the rear hangers, or over the receiver hitch frame. Then drive the bronco forward to tighten the chain which loads the rear springs. Then chain the front down with a boomer on each side to load the front springs.
That goes along with my training.
I had a training class on hauling cars. Yes, work spent the time to put me through a class to safely transport vehicles. We also have multiple professional transport trucks come through weekly and they all do the same. Suck down the suspension so it doesn't move. It's how the professionals do it.
I have also know of the opposite and they lived, pull the car on the trailer, put the transmission in park, drive away. Yes it is wrong. But wrong works more often then not. It's when you have to do that emergency double lane change at highway speeds you never planned on ever doing that you need things set up right. Having the cargo leaning while on the trailer isn't the best for emergency handling. Look at how the pros do it.
miikee73
Shadetree Guru
Aloha
I just bought a trailer and haven't purchased straps yet,so this thread is helping me decide. On the subject of U Haul....I can find nothing good to say.
Wen I help[ed my son make a 1000 mile move the day before we were to pick up one truck (reserved 2 weeks out) ,they called to say a truck wasn't available,but would give us 2 smaller trucks. Well that didn't happen. I ended up renting a local truck that I had to drive back. It was a local co. and the truck was new. They gave me ample time to do the trip at the price Uhaul quoted. Penske wanted twice the fee for a 1 way trip.
Years later I rented a car dolly form Uhaul for that same 1000 mile trip.After loading the car and heading out there were so many rattles that people walking were turning around to see what was making all that racket. I turned around and went back home and cut some wooden wedges to drive between the deck and the slide in ramps....much better!
Bukin 67
Bronco Abuser
I saw a couple of people mention fish tailing. This will scare the crap out of you if it happens. The best ways to make sure it doesn't is
#1 remember thr '60/40 rule': 60% of your weight should be distributed forward of the centerline of the axles, provided they are placed at the correct location on the trailer in the first place, which should be with 60% of the trailer weight forward.
#2 the trailer should be level when hooked up and loaded. If the drop hitch isn't long enough, the rear of the trailer will be lower and weight will transfer to the back causing you to fishtail even if your weight distribution was good.
For the 60/40 rule, that comes to 10% tongue weight.
A great place to start is to place the CG of the vehicle even with the front axle on a tandem axle trailer. Loaded hundreds of trailers and took a long time to realize that the CG is almost always in that location after getting everything set right (using scales, knowing real tongue weight, etc.). Now I just start with that spot and rarely have to make corrections and if I do, they are generally very small.
jw0747
San Antonio, TX
On my '73 there are four oblong holes cut into the bottom side of the frame, two near the front and two in the back. These holes are located in near optimum position for attaching straps. Using these type mini-j hooks attached to my straps and inserted into each of the four oblong holes pulls the suspension down so it doesn't sway. Been doing like this for several years and so far no problemos.
http://www.hookswreckersupplies.com...87940E45C405634E923EAA4FF53704.m1plqscsfapp04
