broncobird
Newbie
- Mar 13, 2013
- 37
Later model striker looks like to me.
There are some differences throughout the years, most notably the early 66 tubs have a bunch of unique features that start to go away in 67, 68 and gone completely by 69. The addition of lower side reflectors in 68 & 69 that changed to side markers in 70. You also have the tell tale 66-67 door locks and internal handles that changed in 68, removable upper window frame on the door from 66 to 68 and then later you have the unmistakeable fuel door on the 77. There are many other differences to add with vacuum wipers from 66 through early 69. Basically the tubs remained largely unchanged from 70 through 76. Here you will have to dive into the dash panel layout as that had several changes. An internal change I have noticed on some we have restored is sometime after 73 we have seen the loss of the bulkhead fasteners in the floor since they stopped production of the half cab. The hoods remained the same from 69 on until 77. It has a unique forward rib that was 77 only stamped to accommodate the larger distributor cap. I say 69 on because I have seen some difference in the under hood structure but am not certain as to what year that was or if they were aftermarket hoods which I am sure someone will chime in on.
Do you now if the windshield frame is bolted or welded on? 66-68 bolted, after that welded.
I also have a Frankenstein. 68 body on a 75 frame with 76 axles, and the old hood from my 73.
I can't tell if it's oval or round lol, what's the end look like? Rear shock is pointed to the rear, but that could have been added as well.
What does your front drivers wheel tub look like? Does it have an indented ridge on the side that faces the steering column or is it mostly flat? If it’s mostly flat it’s 66-72. If it is indented right beside where the steering column goes ( for clearance) then check out the other pics for 73-75 and 76-77. Below are some pics. Let us know which one you have.
Blue71
73 and later have a box section added to make room for a PS box.
As well as the fresh air intake hole in the core support on the '73-newer ones as well.
-the fuel door had been modified.
I am not sure about this but my 72 has what appears to be a date stamped on the cowl/firewall right above the cable hole for the heater shut off valve. It is a stamping that looks like a date ending in 72.
Here are some pictures...
You carry your "parking brake" with you there Todd?;D
I've seen that Bronco before. Either here or out at an event perhaps. Seems like I remember the pain scheme from some images here on the forum.
You get it from a member here? Looks pretty cool.
I am not sure about this but my 72 has what appears to be a date stamped on the cowl/firewall right above the cable hole for the heater shut off valve. It is a stamping that looks like a date ending in 72. Ken
