How did you run your sniper wiring?
NCSUWoj
Lynchburg, VA
Thank you gentlemen!
Your welcome!
Here is how mine ended up. Still have some tidying up to do but essentially have it all in place. Ended up with the relays on the firewall. Right now the fuel pump primary wire is pulled across the back of the engine and down to the driver rail. May end up running into the dash on the PS and back out the DS, just haven't made up my mind yet.
I have eliminated (unpinned) as many of the unused wires as I could from the Sniper harness and the Centech as well.
I do have the coil wires run separate from the main hack of wires trying to follow the sniper instructions. Hate to leave it lay there but for now I don't want to deal with any electrical interference.
I have both main harness connectors laying on the back of the intake. Will work up some method to secure it all once I get the O2 sensor and wiring finished up.
willtel
Im going to go straight down the firewall and then straight across I think to the outside of the frame. Im debating to be honest. inside vs outside. My fuel lines are on top of the frame. im going to use these to hold the wiring bundles in place
https://static.summitracing.com/global/images/prod/xlarge/ear-171006erl_xl.jpg?rep=True
thanks EPB, ill check that stuff out.
Here is another option for wiring clips if you are planning to drill holes to mount them. They come in mild steel or stainless.
https://www.tmrcustoms.com/collecti...cts/bolt-on-zip-tie-tab-cable-tie-tab-10-pack
gr8scott
Looks good, very clean.
