Sounds like a good plan. Expensive... but good. Sorry 'bout that!
And here's something to consider too, just in case you want to spend another 30 or 40 bucks or so. Hey, you own a Bronco, get used to it.
Do you know what your alignment specs were? Expecially caster angle, since lift kits change that in a negative (literally) way. What I'm thinking is that now is the time to install some eccentric ball-joint adjusting sleeves. They take the place of the standard preload collars that come with the ball-joints.
The standard ones just set the preload tension on the upper joint, but the eccentric ones, as you can guess, can be adjusted to also modify your caster and/or camber angles for better alignment. Only good fo up to 1.5° max, but hey, with our Broncos, anything is an improvement!
Just thinking out loud here. Read some other threads on alignment and you'll get a real snoot-full.
Oh, and when it comes time for the u-joints, just ask here. It's actually pretty straightforward as long as they're not all rusted in. And even then, it's not that bad. The first time's a pain, of course, but you'll get the hang of it.
Or is that, the "swing" of it, when you decide to use a bigger BFH?
Have fun.
