All ready to pull but can't get the engine to come forward at all.
Reading the "How to Rebuild Small-Block Ford Engines" mentions that some older enginges have stud motor mounts but doesn't say one word about what to do if that's what you have.
Luckily I stumbled on a decent forum search and came up with a quote from Bigmotormouth back in '06.
My best advice is to unbolt the engine mounts first and then pick up on the 302 and remove the engine mounts. Then you can let the motor drop farther down to get at some the harder bolts along the top of the bell housing.
It felt like a chinese puzzle. I couldn't slide the motor forward to disengage the transmission because the studs were blocking any forward progress and I couldn't lift the engine high enough to disengage the motor mount studs. I'll go pull the motor mounts off and see if that does the trick.
I'd consider a 351 also , if you have to go the replacement route. That will make the Bronco even more fun than it was in the past.
I think a 351 would be beyond my skill, budget, and comfort level. I'm not looking for rockzilla out of this, I just want a dependable daily driver and weekend semi-warrior.
I also found my first evidence of the work of a poor mechanic. There were 4 empty bolt holes between the bell and block, and no bolts at all holding the bottom plate against the bell housing.
I went ahead and pulled the intake manifold so I could use one of the intake bolts and get more threads engaged to hold the chain.
I was also suprised when I removed the clutch frame pivot bracket and the metal piece between the bell crank arm and the clutch arm just fell off. It's just held in place by the return pressure of the clutch arm pushing it over the threaded rod extending from the bell crank arm.
By the way, what do other car owners do when they don't have those big flat fender wells to set tools and bolts on?
