How to make a quiet Bronco?
kiddingknot
Orlando
I'd love to see a thread collecting all the ways to eliminate unwanted noise.
Some people want their Bronco to sound really powerful, but I want my mostly on-pavement Bronco to run quiet, like a modern truck right off the lot. I'm not going to put a hardtop on it, so I'm doomed to hear wind noise. I'm going to put some all terrain tires on it so I'm doomed to hear some tire noise. But what else can I do to quiet it down? What have you done to yours to get rid of noises, including engine noise, replacement exhaust/muffler systems, and elimination of various squeaks and rattles coming from various places on your 40 year old truck?
Stock replacment muffler does wonders.
Clutched cooling fan works for fan noise. Electric is even more quiet when off but tends to be noiser when running and takes other upgrades to the eletrical system to handle the power that a proper cooling fan will require.
Closed air cleaner with helps with intake noise.
Keep the inner fender to block engine noise coming out the wheelwells.
Rattles are addressed on a per-rattle basis. Same with squeaks. Each is unique and will take its own fix.
jsnouffer
Silencer tailgate hinges and tailgate support cables will reduce some squeaks.
Sent from my iPhone 5 using Tapatalk
fatboy4211
Ennis, TX
walker 21400 muffler! took the drone out. now have a current mdl stock truck sound to it.
now i can hear the squeaks and wind.......they sound better
73stallion
Eugene, OR
Turn the key to the off position
Agreed. Sorry, but an early Bronco will never be as quiet as a new F150 or Silverado. Lots of carpeting in every corner over DynaMat, stock muffler and stock air cleaner as previously stated. But if you're never gonna run a hard top that you can insulate, then there's no cutting sound at all.
BluebroncoNC
Asheville, NC
Tire noise, yea, expect that to be loud. When I'm out bicycling the thing I hear from the furthest reaches of the serene Blue Ride Parkway, no not loud exhausts or Harley's running straight pipes, but tire whine of 4x4's.
AZ73
A lot of people run Rhino liner and Dynamat. I'm taking a slightly different approach. I'll be mixing in ceramic microspheres into the primer coating that wiil be on the underside, engine bay, firewall, inside the fenders, inside the doors, floors, and inside walls of the truck bed. Also the inside of the top. This will add thermal insulation also
http://www.hytechsales.com/insulating_paint_additives.html
Then a layer of dynamat inside floors and walls, with a foam top, then carpet on the floors. All this is probably overkill because there are LOTS of places for noise to enter (grommets, etc) as well as lots of noisy parts (headers, tires, fan, intake, muffler). You can wrap the headers (but they're really good looking), get tires with good sound ratings, clutch the fan as noted above, seal your intake with a enclosure, and use a better muffler.
You'll never get rid of all the noise. The best you can do is minimize it. And as noted, as soon as the top comes off - forget it.
Now I did have a buddy build a sound canceling system that he ran through his stereo for kicks (on a regular car), like those Bose headsets, but it really wasn't that effective. Parts for it are cheap on-line, but there's too many sources of noise to pick up in the car so just wearing the actual headsets was significantly better.
Stroppe-Envy-77
(Check my signature at the bottom!)
Some of these are duplicates already mentioned, but here goes:
1. Single exhaust, exiting behind rear wheel on passenger side (as factory). Flowmaster 70 Series muffler - nice sound from the outside but you'll barely hear it while driving.
2. Dynamat in the doors. Insulation everywhere else you can put it, including in between the fiberboard headliner and the roof.
3. Dynamat under-hood unsulation. (That hood acts like a big drum.)
4. Gas struts on liftgate (they keep slight pressure on it to combat rattling); various sound deadening methods for tailgate hinges.
5. Spray-on rubberized undercoating inside each wheel well.
6. Extra stick-on weathestripping to supplement the factory stuff around doors and windows.
After the basics noted above, then you'll just be chasing individual squeaks and rattles. White lithium grease, brush-on "liquid electrical tape" and other little tricks will eventually eliminate all the noises you're hearing.
JLBachs
T-case mounts did a lot of good for me - they cut down on the vibration that was causing a lot of other things to squeak and rattle in the first place. If your Bronco is as nice underneath as the pics in your gallery suggest, you've probably already taken care of those though.
Fireball05
Stroppe-envy has a good list above. If you're going to run a soft top, I wouldn't go much further than that because you'll be spending unnecessary time and money and won't see any improvements. With a hardtop and proper sound deadening and interior insulation, you can probably have a pretty quiet ride. With a softtop, not so much.
A few years ago I had a very nice Miata. Sound deadened the entire car, including firewall, trunk area, cabin and hardtop. Other than a nice thud when closing the doors, with the hardtop off you'd be hard pressed to tell all the time and effort I spent with the deadening. With the hardtop on it was a different story. The radio sounded awesome and the interior was very quiet.
K
kiddingknot
Orlando
Stroppe-envy has a good list above. If you're going to run a soft top, I wouldn't go much further than that because you'll be spending unnecessary time and money and won't see any improvements. With a hardtop and proper sound deadening and interior insulation, you can probably have a pretty quiet ride. With a softtop, not so much.QUOTE]
I hear what you are saying, and I'm sure you are right on the highway. But truth be told, most of my driving is at very slow speeds. My drive from my house to my office takes 79 seconds. The grocery store, or 7-11, or the hardware store, not much further. So I don't have much convertable wind noise. I go 25 to 35 on rough old uneven charming brick streets. It sqeaks and rattles and pounds me. All the sqeaks and rattles and pounding I can eliminate, the more I'll like it. Don't need or expect perfection. But I know it can be improved, so I'm going for it. :)
Fireball05
What suspension/shocks are you running? That might be more important than sound deadening then!
One benefit of running without the HT is you won't have to worry about the liftgate rattling :)
rguest3
Single rear exhaust, gibson muffler, without large pipe.
If going to AT tires choose the Michelin AT2. Look good, last forever, very quite.
Stock suspension? Replace with newer soft lift and Bilstein 5100 shocks????
Wow, the list could be long here.....
nvrstuk
PNW
After running with just a bikini top for 12 years, I resurrected a 1/2 cab and made new sides for it-and it's totally open in the back- no window or bulkhead (I have a windscreen there only). With that qualifier, there was a HUGE difference in wind and overall noise between running with no top to running with a "half" of a 1/2 cab. : ) It's still loud, but noticeably quieter.
Stereo sounds tons better too!
Brnco302
I had a lot of noise coming from my doors.I am in the process of changing all the window tracks.I also put dynamat on the inside of the steel door panels.The inner door rods were rattling so I replaced all the bad door rod bushings.Helped some let you know more when I get it put back together.
Fireball05
Dynomat or similar on the door shell and the door skin where the door panel goes. Just a few pieces goes a long way. Also, a piece of hose or heat tube around the end of the door cup handle is a trick I learned from someone on here that will eliminate one more of your interior rattles.
Bigpitbull has an awesome suggestion above. With the key in the OFF position, mine is darn near silent!!! ;D
