As 'bowsher and others said. All stock (except for the electric pump) and normal.
Yep. All year EB's had plastic auxiliary tanks with steel skid plates held in place by straps. In '77 even the rear main tank was plastic and slightly larger capacity. Held in place by a steel skid plate.
it has a electric fuel pump
Not stock, but many have been switched over for one reason or another.
In fact, it was very common for the rough-n-ready off-road, and rancher types that bought many of these rigs originally to install an auxiliary pump right away, in case the stock mechanical pump ever failed. Or sometimes to overcome vapor lock, or just for more versatility.
Stock again. All year models of early Bronco used a brass mechanical switch there. Owners got pretty deft at switching the lever too, if they ever forgot to switch the gauges and ran out of fuel!
There were at least two variations, where a couple of model years delivered to certain areas (usually high altitude or very hot) that got return line systems where the valve had six ports, rather than the standard three.
Stock again. The switch might have been changed, but if it's chrome, has a long-ish toggle, a chrome bezel with the functions marked, it's stock.
Earlier models might even have had a manual choke and yours could have a manual throttle control knob right there by the switch. Used to control engine speed during PTO equipment use.
