How to tell when front axle is centered?
airbur
Castle Pines, CO
I think my front axle is off-center, tending towards the driver's side a bit. What is the correct way to measure this? I'm looking at how much the tire sticks out on each side. I have the original non-adjustable '76 track bar. I'm thinking with an adjustable I could "push" the axle more to the passenger side but just need to know how to measure it. I do have a drop-track bar bracket.
Thanks!
addicted
Broussard, Louisiana
Get the tires pointing straight ahead. Make sure the tires are the same psi. Place a straight edge against the tire centered at the hub. And then measure to the fender at the same point on both sides. I used a 4 foot carpenters level. You probably need an adjustable track bar to fine tune it.
addicted
Maybe. But it will look centered ;D Its like hanging a door level and plumb in a crooked house. Your door looks scewed up. Not the house. He wants his tires to stick out the same from the fenders on either side.
airbur
airbur
Castle Pines, CO
Is it something I shouldn't be worried about? I was thinking having it off-center would affect handling a bit, no?
addicted
Naw. Not really. I drove my 79 off center for years and never had any issues. Then I centered it with an adjustable track bar and couldnt tell the difference in handling. I guess technically some could argue that you may see tire wear being uneven due to more weight on one side but I never noticed anything.
SnwMnkys
Orem, Utah
The more or less weight you add to the vehicle the more or less its going to be off centered. Get it "close" enough but its really not that important.
Louie
I think it would throw off handling a bit in an extreme maneuvering condition. Plus, you don't want to be like that guy going down the road who looks like they're driving sideways :-X
Steve83
Not handling exactly, but alignment (tire wear, return-to-center, thrust angle). That's why I say center it on the frame.
So you'd compound the error??? And then when the body eventually gets set right, he has to RE-do the axle? I do things a little differently... ;D
addicted
I must of missed where he siad his body was tweaked. In any case, you win. lol %) Your method is more correct. I hope he doesnt get a heavy person in the passenger seat. Then he might have to recenter it again!
