Hydroboost Brakes - Operation When Motor Stops
Jeff10
Indianapolis
Hey Everyone,
I have been running hydroboost brakes for about 2-1/2 years. I have no complaints. In general, I am really pleased.
The only complaint is that if I kill the engine, the pedal drops quickly. I'm not really sure how far it drops (all the way to the floor, or not quite that far).
Today on a small climb I didn't grab a deep enough gear and before I could get stopped, I killed the motor. I went for the brake quickly; however, I wasn't quick enough. The pedal was pretty far down. I'm not certain if I rolled to a stop against a rock on the trail, or if there was enough pressure in the brake line to stop it. As soon as I hit the key and the motor started, the pedal popped back up and the brakes held firm.
I'd like to make sure this problem doesn't happen again. I recently bled the brakes. With the hydroboost the brakes work awesome.
Am I missing something? Any suggestions?
Thanks,
Jeff
Joker11
Yuma, Arizona
Usually you will get one solid pedal push after you stop pumping pressure from the P/S pump.
That pressure should be in the accumulator. If you instantly lose pedal, I would be investigating the accumulator. It basically stores hydraulic energy. But not much.
If you lose power and have to stop, I wouldn't start to press the brake and then release it. Because I don't have enough in the accumulator to do much more than one pump.
That being said, you should still have some braking at a much increased effort at the pedal.
Now I am wondering if your pushrod is too short. No pun intended. Lol
Jeff10
Jeff10
Indianapolis
Hi Joker,
I'll do some testing on the street to see if I can provide more complete details.
I know I grabbed the brake pretty quick trying to keep from rolling back, and it went toward the floor pretty quickly... I don't believe that I pumped it; but, I'm not completely sure.
Is there a way to confirm the correct pushrod lenghth?
Thanks for your thoughts.
Jeff
pbwcr
I guess you do have a problem because HB has the same design criteria as Vac boost which is 2 or 3 stops after the motor quits. Motor off you should get a pedal that is the same as no assist at all like the old days. After 2 stops the rig should stop fine with lots of leg pressure when the motor is off. And if you have front disk brakes the pedal pressure required will be greater than the stock drum brakes.
Yes, try adjusting the push rod or replace the accumulator which is why you get 2 more stops after motor off.
Good thing is to test before you drive on the trail.
PW
Jeff10
Jeff10
Indianapolis
Hey Guys,
I checked the hydroboost operation a little while ago.
At a stop on an incline, with the brake pedal pressed when the key is turned off, the Bronco stays put. If I let off the brake, let it roll a little and then reapply the brakes, the hydroboost appears to be functioning and the Bronco stops without too much pressure. If I let off the brake and let it roll again, it takes quite a bit more pressure to get the Bronco to stop... but, it does stop.
(I do have front discs, too.)
Maybe I just did a stutter-step on the brake pedal yesterday... I'll be more careful.
I'm also wondering if replacing the accumulator would add a safety factor.
We'll be doing some fairly mild trails this week, so I will play around on some steeper inclines to make sure the manual operation works similar to the original non-powered brakes.
Thanks for the input.
Jeff
Joker11
Yuma, Arizona
If you want a larger safety margin, you could install external accumulators inline before the hydroboost unit.
It is not a factory design. But since when is factory design better instead of cheaper?
I am quite involved in hydraulics. If you want some help, send me a PM.
I think I might even do it on my own rig just to see how much I like it. Thanks!
tmbuehrer
homer michigan
I have had a few master cylinders cause this problem they work fine under normal operation but when you trying to panic stop or hit the pedal quickly the pressure blows past the seals and The pedal goes to the floor
73azbronco
Joker, I was thinking of using an external accumulator and it looks like one off a land or range rover would be the cheapest path. My concern is check valves inline causing restriction of flow while operating. I was also considering wiring in an electric pump with a low pressure on and operating pressure off switch, in other words if ignition is on, and engine is running, the electric pump is off, but if engine dies, pressure drops, then electric pump kicks in. Thoughts .
Apogee
Tangent, OR
X2...if you're experiencing a low brake pedal scenario without power assist, then my first thought is that it sounds like your master cylinder could be bypassing fluid and in the early stages of failing.
What you should expect when the engine is shut off would be a high, firm pedal with low brake torque and/or excessive leg effort. This will vary depending on the number of pedal applications and the accumulator size on the booster (internal versus external), etc.
Jeff10
Jeff10
Indianapolis
Hi Apogee,
I don't think we'll be doing any more wheeling in Moab before we head home. So there's nothing critical at the moment that needs to be done.
I'm thinking that I'll buy a new master cylinder ('82 Corvette, I believe) when I get home, just to get away from a rebuilt MC.
I had one incident on a fairly steep fin... I broke the back end loose and couldn't recover. With the front lockers there wasn't a problem. I shouldn't have needed the lockers, though... I was glad that the motor kept running so that I didn't need the brakes.
Thanks for all the advice, guys.
Take Care,
Jeff
