Hydroboost issue
Jaybr
Hey folks,
I’ve installed a complete new braking system on my 74, front and rear disc, master cylinder, proportioning valve, new lines, and Hydratech unit. All parts from JD.
I originally bled the brakes by myself with an air hose vacuum unit and couldn’t get the pedal tight. Today I got my wife to help and did it old school method, pedal still goes to floor.
Did some reading here and decided I better check the gap between the hydroboost rod and the MC piston, and bingo found my problem.
Excuse my rudimentary measuring technique but couldn’t fit my calipers in there. In the pic with the screwdriver, it bottomed out in the MC and wasn’t hitting the piston, yet still longer that the rod in the hydroboost. I have approximately 1.5” gap, the rod is depressing the piston but it must be close to the floor before it reaches.
I’ll call JD tomorrow and I’m sure they’ll resolve this, but I thought I’d post in case anyone else runs into this problem, and maybe save them some time.
EPB72
Pleasant Hill, CA
Looks close to me ,,remember the protrusion on the master cylinder sets inside the hyroboost and adaptor so that's another 5/8 of an inch about,, that you need to account for,,Did you bench bleed the master cylinder
Jaybr
Jaybr
Good point and I missed that, I’ll go measure again. I did bench bleed the MC.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The difference appears to be the thickness of the aluminum clocking ring. Typically there will either be two different length push rods to choose from depending on if you're using the clocking ring or not, or a metal slug the same thickness of the clocking ring to install into the master cylinder piston to make up for the extra space created by the clocking ring.
Jaybr
Jaybr
The clocking ring is 1.5” thick, which is exactly the gap I measured
Just call this the dumb post of the week and I’ll try bleeding again.
Jaybr
Jaybr
Bled the MC again, then all 4 corners. Pedal still goes to floor.
thegreatjustino
Stockton, CA
Again, you either need a longer push rod to make up for the clocking ring or a 1.5" slug inserted into the MC piston to make it work correctly.
Jaybr
Jaybr
But the ring on my MC is 1.5” thick and goes into the hydroboost unit making up the 1.5” difference in my measurement.
I apologize, but what am I not understanding?
Jaybr
Jaybr
I just went out to the shop and checked, as soon as I touch the brake pedal fluid squirts up into the reservoir so the rod is making contact with the piston with no significant gap.
thegreatjustino
Stockton, CA
So then it sounds like if you remove the clocking ring, the push rod from the booster will be too long?
If that's the case then you don't have the issue I previously thought you did.
I've had to use the slug before on certain HB setups. It's all dependent on the combination of the length of the push rod and the depth of the piston. If you think the lengths are correctly matched, you should be good there and are still in search of your issue.
Are the bleeders on your calipers pointing up or down? The correct orientation would be bleeders at the top, but it is possible to install them upside down which will cause bleeding issues.
Jaybr
Jaybr
Bleeders are on top, Ford calipers up front and I believe GM in rear.
I’ve pumped nearly 2 quarts of fluid through the system now and I’m not seeing any bubbles. My understanding is with air in the lines the pedal will get stiffer as you pump the brakes and compress the air. I can pump the pedal 25 times and no change.
I’m leaning toward bad MC.
EPB72
Pleasant Hill, CA
you can put plug fittings for the maste cylinder ports and no air or good master there will be no piston trvel ....also if gm rear calipers with intregal park brake make sure the pistons are pushed out not uncommon they don't work properly
Jaybr
Jaybr
That could be the problem, I just tried to adjust and they are tight enough that I can’t turn the nut enough to re-index the lever though.
EPB72
Pleasant Hill, CA
,,,,OK a 1/4 inch to 3/8 off the stop would be normal..
Jaybr
Jaybr
Went to 4 parts stores yesterday and couldn’t find one of the plugs needed to test MC. Tonight I welded the hole shut on a fitting and made my own plug. The master cylinder is fine, with ports plugged pedal is hard as a rock.
If I plug the ports one at a time will that tell me if front or rear are soft?
Jaybr
Jaybr
After a lot of time and cussing, I got the parking brakes adjusted properly. Bled the rear brakes only this morning and got them tight, BUT they don’t get hard until the pedal travels about 3”. The pedal only has 4.5” of travel.
Hooked up the front and bled with nothing more than a couple tiny bubbles and pedal goes to floor. The brakes are tightening up, at least I can’t turn by hand with pedal depressed, but the pedal going to floor is obviously a problem.
I’m using Lucas synthetic dot 3 fluid
The only rubber lines left in the system are the front and rear flex lines from frame to axle, and line to front calipers. Front caliper lines are new.
Also a new proportioning valve in the system pictured below.
Any suggestions?
