Mikekerney
After lowering my Bronco and going back to stock size tires, my Hydroboost has way too much stopping power. With the slightest touch I can lock them up and kiss the dash. I like my dash, but not that much. So, I'm going back to stock power brakes.
I'm including the following parts:
-Astro hydroboost unit with new seals installed from Pirate Jacks. Bracket modified to bolt to stock location by opening up the existing holes. Includes correct length push rod
-Master cylinder- less than a year old, just never painted it
-Russell fittings to convert to inverted flare hard line and stock hoses (over $100 in fittings)
-Hard line to steering box with fittings for box
-Pressure line to power steering pump
-Power steering pump with fitting added for dual return (no pulley). Pump is one year old from Advance Auto Parts, housing is 94 Mustang GT.
-Return hoses
-New Wilwood proportioning valve and hard lines to stock proportioning valve
-I'll even throw in the braided throttle cable that you will need since the existing mechanical throttle linkage won't clear the hydroboost.
Buyer pays shipping.
-Return hoses
