Outshine2
Ok... LONG story here please hang in there... I got a new Bronco today, 75 with a 302 and a C-4 auto tranny. I met up with the guy and took about 2 hours looking over the whole thing. It was VERY clean, and looked very nice. I crawled under it and everything was spotless, and tight. He claimed that he had alot of work done to it, including a very recent and expensive tranny rebuild, etc... It had an Edelbrock 4bbl carb and he hadn't gotten a kick down linkage. I drove it around for about 45 mins straight and it acted great. Shifted just fine, just had to manually downshift to get into passing gear (cause of the lack of the kickdown cable). Shut it down a few times and started it back up, worked just fine. Tested everything I could think of and it all went great. Well after about 2 hrs I decided I would go for it.
I payed him pretty much all in cash and headed off back home (about a 2 hr drive). Now we stop to eat on the way back home and when I come back out it took about 2 minutes of cranking just to get the thing started!!!! WTF ?:? Oh well, I figure maybe it was just a little flooded since it had started fine before. Drove the rest of the way home (about 60 miles) and near the end of the drive the tranny starts acting up and won't even shift into first gear from a dead stop!!
I get home and I go inside and freak out for a while... I stay inside for a bit and decide maybe I'm just not used to auto trannys or maybe it's because of the absence of the kickdown lever that I'm having problems. So I go outside and start it up (took forever to get started AGAIN) and the tranny starts out in 1st... but won't shift out of it. I can manually shift it, and it manually shifts fine, start in 1, shift to 2 and it does fine, go to Drive and it goes back into 1st gear again!! So, I drive up and down my street trying to figure out what I can do to convince the tranny to shift out of 1st when in drive... decide it's not going to happen and then all the sudden it starts acting fine. Starts in first and appears to go through all the gears as it should.
So now here I am, feeling like he just pulled some sh*t on me... I am so confused on how it could drive so well for the couple hours I was driving it around, and now it could have so many problems. I'm so mad at myself right now, but I even had a buddy with me and he said it ran really well too. Unlike most of the vehicle purchases I have made I took alot of time to check this Bronco out and it seemed very solid.
Now it's very hard to start when the engine is cold (sitting over an hour or so), it's leaking fluid from the dip-stick hole, and the tranny is acting up! I didn't abuse the thing AT ALL on the way home, actually just an interstate drive...
First, what do you guys think about the trannny? Does this sound like something relatively simple, or does this sound like the tranny is gone?
Second, how can I get or create a kickdown linkage for my carb?
I know this is all MY fault, because I did see it and drive it first before buying it, but I SERIOUSLY looked over everything I could and drove the sh*t out of it and it all checked out then... I just am so angry that I finally found a Bronco that I wanted and spent some good $ for one that is possibly crap
Any suggestions, advice, or even words of encouragement??? I'm so ready to just throw it on Ebay and cut my losses and be done with the Bronco world... :'( If you are still with me then thanx for hanging in this long. :'(
