flint_knapper
BRONCO GOD
yep check the modulater valves vac. line. if it is in place <br>then go get a replacement for it. when you take the clamp off be sure to have a drain pan under it I think there is a small spring or some kind of UFO behind the valve becareful not to loose it this will lower your fluid level also.
be sure not to be under it when you pull it loose, nothing like hot atf fluid in the face. be sure to use atf fluid rated type F. the price you paid for a clean bronco sounds fair. ;D edelbrock and carter are the same nowadays. the kick down rod can be had at any of the bronco venders that have used parts. the carb might need what is called a ford kickdown bracket, it mounts to the throttle lever on the carb if it doesn't allready have it they are under 20 at summit.
