A vacuun leak in my intake manifold caused the exact same problem in my truck. I'd have have to agree with everyone else who say it sounds like a vacuum leak. The kickdown can def. cause problems, there really is no such thing as a "passing gear" the kickdown increases line pressure making the trans shift to a lower gear. It is not intened to be an on off kind of operation. On all the c4s I've had it is connected by a rod, this rod moves when the throttle moves increaseing line pressure at the point of enough pressure it will make the trans shift. You can drive a c4 without it personally I would not recommend it, an AOD trans work similar, but driveing it without the throttle control valve cable (same operation as the kickdown rod) can be deadly to the trans. As for the deal you got on your Bronco, at my body shop we charge atleast $2000 for a paint job as long as its no color change. I'd say you got a good deal.<br>Don't won't to step on any toes, but Weber makes Edelbrock carbs. The name is cast into the carb body, it is in my anyway. <br>Keep the faith.<br>
