identify this part
Retoohstyoh
When tearing off parts I forgot to mark where this came from. Can anyone help me out? Measures approx. 2 3/4" across the ends.
half cab
Guru Bronco
Looks kinda like the mount end of for a stabilizer on the front of D44?but would have had to been cut off though.
Stabalizer mount?
Only 1 hole? Any signs of broken welds or cut lines?
R
Retoohstyoh
It does sorta look like that but the stabilizer mount is attached and stabilizer bolted on. I have most of the front back together. I removed both gas tanks. Maybe it came from one of those?
How rusty was the Bronco? If in pretty good shape, that part does appear to be something from underneath. But the hole is too close to the curve for it to be either a piece of the top of the shock mount, or a piece of the stabilizer mount.
Almost looks like part of a crossmember hanger for the transfer case, but I think those are square, and your bit looks like it has an angle to what would be the long side of the mount (left side in the pic).
Was thinking it might be a reinforcing plate for inside the structure of a hard top. Like something they'd put in the rear corner. But it just doesn't look like the right shape.
If it was in a box-o-parts though, you may just have to consider that it never came from an EB too.
We like these mysteries though! Love to find out what it is.
catfan
I was thinking an end off a tank strap but maybe not.
R
Retoohstyoh
There was no extra parts included. I'm sure I removed from somewhere. The underneath was pretty rusty Paul.
Jebus
Longview, WA
Mine is a 68, and I had to move the brake line mount at the rear of frame where the rubber axle hose connects to steel line, left side, at frame. Mine was bolted, easily moved and it looks different, but close to that part.
Were early, 66, 67, brackets welded to frame?
By enlarging that pic, you can kinda see where a brake hose clip has made a pattern on your part. There is a front brake hose drop to the axle, at the frame end, a similar bracket. Mine is bolted there too. (On second thought the front axle brake hose just bolts to the frame)
There is a bracket under the body for the park brake cable, drivers side floor, right rear corner, mine is currently torn away, but it is wider than that piece.
It does look like some kind of clip was on your part at one time...
chuckyb
I was thinking a piece of the front outer brake hose bracket for a Dana 30.
Muddy1966Bronco
Bronco Building Mom
Tupelo, MS
My first thought too. Corner of the frame and in front of the gas tank, driver’s side. I didn’t know they were removable.
Jebus
Longview, WA
Your right. I remember now, man I'm getting old, I made an L bracket. The original bracket is welded.
The 2.5 pipes were too close. The new teflon hose pointed right at it, so I moved the bracket I made to the old fuel tank strap hole on that top side. Just enough.
R
Retoohstyoh
The rear brake hose mount is still attached to the frame. So that’s not it. Maybe I’ll find out once I start putting more things back together.
