BroncoMark
I have the Ididit tilt column and the column mount that Chuck sells. I was hoping that the mount would hold the column snug enough that I wouldn't have to weld it to the column, but no such luck. If I tighten the bolts all the way down I can still rotate the column and lift it up about 1/4 inch. Also, the column sits too high in the dash and I can't get the column trim to line up. Anyone have any ideas? Even if I tacked the mount on I'd need to shim the mount down some, but I don't have a welder anyway.
