Ididit column mount
BroncoMark
Irvine CA
I have the Ididit tilt column and the column mount that Chuck sells. I was hoping that the mount would hold the column snug enough that I wouldn't have to weld it to the column, but no such luck. If I tighten the bolts all the way down I can still rotate the column and lift it up about 1/4 inch. Also, the column sits too high in the dash and I can't get the column trim to line up. Anyone have any ideas? Even if I tacked the mount on I'd need to shim the mount down some, but I don't have a welder anyway.
WyleCoyote
I think you have to weld it on, at least that is what is says on BC website, but there is 2 sizes to the mount, a 2" and 2 1/4". Did you get the wrong size perhaps?
bax
Old Member
My mount was very tight. I installed it and had to shim it down with 2 washers on both sides just to stop from smushing the tube some.
I didn't know they had 2 sizes.
Desert Thrasher
The ididit column mount from WH is well worth the money. Fits great.
csjr
Lighthouse Point, FL
I used Ididit and went to a local speed shop for the column mount. It looked like the WH part and fit the tube properly, but I had to do some fab work to get it to bolt under the dash. I agree with the others, if the WH part is a simple bolt in, and since you don't have a welder for the part you have, then it is worth the $60. I bet I spent 4 hours working on my mount--not counting the rest of the work--and I spent about the same.
Tuck
I love this site. I have an ididit column & have the same problem with the mount. I'll be ordering the WH one shortly.
fordguy
if you want more drop look to the street rod vendors they sell mounts in different drop lengths. Speedway motors probably has them.
cgbexec
Naples, FL
I have an Ididit colum in the box ready to be installed. For that kind of money shouldn't it be a bolt in?
NYLES
Mines a Flaming river colum kit from WH, $1400 well spent, I only have enough installed at the moment to drive it around a lil but sure a nice set up with the auto shifter, tilt, SS....fits like a glove. Came with the WH al model shown above very nice!
a heads up on the steering wheels, what they call thick is more like super fat! but Ive got big paws.
KyleQ
Sorry to sound like an idiot - but what is an idiot colunm?
904Bronco
San Martin, CA
Ididit: Another manufacturer that makes aftermarket replacement steering columns, based on a Chevy design. Most Bronco Vendors sell either Ididit of Flaming River
KyleQ
That's funny, I always think idiot when I see ididit..:D
Haha - I didn't even notice :-X
Thanks guys - trying to learn. I've got a 90's truck, a 78 Bronco, and will be buying a 74 shortly.. Too much info to learn! ;)
