- Mar 1, 2013
- 433
I have been having an intermittent issue when going to start my 76. I turn the key a couple of time and get nothing. Then, usually the third turn, it hits like normal and fires right up. I thought it may be the ignition switch or the starter, but I haven't had time to dive in and start checking the ignition circuit. Every once in a while, typically after I having been driving it, I'll turn the key and the starter, I'm guessing, sounds kind of choppy then fires up. Does this sound familiar? Any usual suspects? Advice of what to test with my meter and readings to look for? Ignition circuit sequence? I would appreciate any help or tips that could be provided. Everything is stock as far as the ignition is concerned.
