Ignition Module/Starter Solenoid Question
mavman427
Nipomo, CA
I'm having a big problem with my new wiring harness. I've wired it up like the picture shows below. When the key is turned on, I get 12V at the S terminal of the starter solenoid, which energizes the solenoid and engages the starter. Does anybody know what's wrong with the wiring diagram shown below? Thanks!
ransil
check your switch , Find the terminal on the switch that only puts out 12 volts when in the start position.
Steve83
Eliminate the R wire. It's redundant, and depending on what it's connected to at the module, it could be the source of the problem.
BTW
Can you reduce that image? It's stretching the page, and it's difficult to understand since the whole thing isn't visible.
mavman427
mavman427
Nipomo, CA
check your switch drawing looks Ok. Find the terminal on the switch that only puts out 12 volts when in the start position.
The switch wiring works fine, it's the "S" terminal on the ignition witch that feeds voltage through the orange wire to the "S" terminal on the starter solenoid when the key is turned to the "START" position.
I think the problem is the white wire to the ignition module is backfeeding the red wire to the starter solenoid, thus making the starter engage at all times.
My understanding of the ignition module is the white wire should provide voltage in the "ON" position and the red wire should provide voltage in the "START" position. But, either this is not correct or my ignition module is bad and passing voltage along to the starter solenoid.
Viperwolf1
electron whisperer
That first diagram has several serious problems. Don't use it.
The wiring you need is dependent on the type module you have. Look in my gallery for the correct one.
mavman427
mavman427
Nipomo, CA
Care to elaborate lol? What are the serious problems? It's basically identical to the painless harness.
Phil's the answer-man, but I'll at least point out that the Yellow wire from the battery is feeding constant power to the module, the coil, and the "I" post of the starter relay.
And the Red wire from the module is "usually" for 12v with the key. (edit: Now I think I see what might be a switch in that pic, but in yellow, my eyes couldn't pick it out at first.)
Just a couple of points for starters.
Are those the colors of your module's wires? What color "grommet" or strain-relief does yours have?
And for my final (hopefully) post-whoring effort of the night...
Back to your original post mavman, the only way I can see for your problem to happen is if either the wire from the key to the S terminal is hooked up to the wrong post on the ignition switch, or the wires are reversed on the solenoid, or somehow there is some feedback coming through from the "I" post to the other side (defective solenoid) causing it to energize.
If you're not getting 12v to the "S" wire when you turn the key on, then I would think it's not the way the switch is wired, but one of the other things.
Try disconnecting both of the little wires at the solenoid, turning the key ON, and putting one on at a time to see if it still does it, and when it does it.
mavman427
mavman427
Nipomo, CA
My little diagram is not totally accurate, in reality I have the yellow wire coming off a fuse box which comes on with the key in the "ON" position. I just showed it coming off the battery to simplify it. But either way, I shouldn't be getting +12V at the S terminal with the ignition switch in the "ON" position.
I've troubleshot the problem and I'm getting +12V at the red wire from the ignition module to the starter solenoid. Since I have it basically wired up the same as the typical duraspark/painless diagrams, I'm leaning towards it being a bad ignition module which is backfeeding voltage from the white wire.
But I'm no ignition module expert, so I don't know whether it should backfeed voltage like that or not. But, if it did backfeed voltage, there would be no point to have one wire for start and one for run as they would both be hot whenever the key is on!
Viperwolf1
electron whisperer
The yellow wire just needs to go away. Of the remaining wires, if they are supposed to be color correct, the black module wire is supposed to go to the distributor instead of the grey wire. Never seen a grey wire on a module before so I don't know where it goes.
I have seen some aftermarket modules with different color wires but the plug and pin configuration allows them to be hooked up in the correct way only. The different module types (strain relief color) also have different pin arrangements in the connectors.
Basically if you want to figure out if the diagram is correct you need to ID the module and then use the connector and pin arrangement to determine the proper wire routing (ignore colors). Or you could just look at the diagrams I've already made, which are correct.
mavman427
mavman427
Nipomo, CA
Well, here's a rundown on my module. It's got the blue plastic strain relief and the following wires (from top to bottom):
-Red
-White
-Green
-Black
-Purple
-Orange
The colors and wiring order don't match up to any of your diagrams or anything else I can find on the web either. So what wire goes where? I'm assuming Black/Orange/Purple go to distributor. Green to neg. side of coil. Red and white must be +12 V ON/START.
I even took it a step further, I disconnected the ignition module and bench tested it. With +12V at either the red or white wire, I get +12V at the other wire. I also tested another module I had from a 76 Maverick and it did the exact same thing. Something isn't right here, anybody have a clue what's going on?
Viperwolf1
electron whisperer
-Red
-White
-Green
-Black
-Purple
-Orange
Wire it just like this. Pay attention to the connector pins not the colors.
Is it important to have the module's case grounded to the body while testing or running? Or is that unnecessary?
Viperwolf1
electron whisperer
The black wire provides the ground for the module. I'm not sure if the alum module case is actually connected to anything inside.
I wasn't sure either. And I think I've seen them mounted to plastic inner fenders on some trucks, but mostly to the steel parts of the body.
Have never tried to run one un-mounted though, So I wondered.
Viperwolf1
electron whisperer
I'll have to see if I still have an old module laying around. Simple continuity test from black wire to case will tell.
