Ignition Module/Starter Solenoid Question
Viperwolf1
electron whisperer
That's going to be a problem because there are no connector pins on this, connector has been cut off. The only thing I can go off of is position or color.
Ok. Red goes to hot-in-run. White goes to hot-in-start (can used "I" terminal of solenoid). All other colors as in my diagram above.
mavman427
mavman427
Nipomo, CA
Well, there's the rub. I've tried wiring it up exactly like that. The problem is once the red wire is hot, it backfeeds the white wire which is connected to the S terminal on the solenoid, which engages the starter.
Viperwolf1
electron whisperer
Could be a problem with the module. Try the white on the "I" terminal instead. It won't engage the starter there and still gets a start signal.
mavman427
mavman427
Nipomo, CA
That would work, but then I would be supplying +12V to the positive side of the coil at all times, as there is a wire running to the positive side of the coil from the "I" terminal.
I also thought about it being a bad ignition module, but I tested another one from a 76 Maverick and it did the exact same backfeeding of voltage between red and white, so I don't that is the problem.
I'm tempted to just leave the white wire off all together and just run the red to a switched source...this is how the PO had it wired up and it seemed to start up and run fine.
