JSmall
- Feb 18, 2004
- 3,224
I would like to verify my diagram with the experts
I took the diagram that Viperwolf created and modified it for my needs. Does this look accurate? Does anything stand out that should be resolved before I start?
I want to use a DPDT toggle switch like Phil shows in his diagram so I have ACC (up), OFF (middle), Run (bottom), and then a momentary toggle for START.
I believe I would need to run a relay for the ACC and IGN circuits the way the AAW harness is configured. I am including a small section of the AAW diagram that shows the ignition switch wiring and a link to the the full diagram if it's needed.
Ignition Toggle Diagram
AAW Ignition Diagram
AAW Wiring Diagram
https://www.americanautowire.com/media/productattachments/files/downloads/92968422 510006 IN 4.0.pdf
AAW Wiring Diagram
