Installed Toms Steering Wheel, now Turn Signals Don't Work.
Mountain Ram
Recovering Masshole
Abingdon, VA
Be careful with it. I used a small puller and it stripped the threads out and I had to get creative...
ObscureMachine
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
Okay, pulled the hub thing. My wipers work. No gauge lights. Emerg. flashers work, kinda. they're erratic and intermittent. No turn signals. No brake lights. Here are pics of the steering column and the wires coming out of the column. I have no idea what I'm looking for.
Thanks for help.
-jim
Viperwolf1
electron whisperer
That column wiring is a mess.
Bust out the volt/ohm meter and start checking voltage and continuity with the switch in the different positions.
'74-'77 Column Connections
Blue=12v from turn flasher to turn switch, circuit #44
white-blue=right front turn and indicator lamp, circuit #2
green=right rear brake and turn lamp, circuit #282
green-white=left front turn and indicator lamp, circuit #3
yellow-black=left rear brake and turn lamp, circuit #283
red-black=12v brake switch to turn signal switch, circuit #810
blue-yellow=12v horn relay to horn switch, circuit #1
white-red=12v from hazard flasher to hazard switch, circuit #385
blue-red=12v from headlight switch to PRNDL light, #19
ObscureMachine
ObscureMachine
World Headquarters
broke out the volt ohm meter.
Flasher switch. blue wire is hot. Two others cycle when flashers are on. (only flash when key is "on."
Nothing hot around the turn signal switch.
Gonna crawl under the dash now.:(
Thanks for the diagrams!
-jim
ilovemaui
Pacific Moist West
I have a Grant steering wheel and ever since replacing the bearings my left blinker works but does not cancel and my right works about half the time and cancels too soon. I'm thinking I just need to pull the wheel again and adjust it.
Yours sounds like it's not grounded.
ObscureMachine
ObscureMachine
World Headquarters
where geographically (on the bronco), does the blinker ground?
