Installing 77 style fuel doors
tsmustangs
All Over
Since this board is about sharing information and have fun restoring I'd thought I'd share with everyone what I learned this weekend. Living in Southern California with access to what seems an endless supply of junk yards. I did a little research this weekend and discovered that the 78/79 Ford trucks and Bronco's use the EXACT same fuel door as the 77 Bronco. Slightly rounded and not that square crap they went to from 1980 on.
This was an awesome find for me since I need to replace the rear one on my 77 due to extreme rust. So one portable generator and one sawalls (gee I wish I had invented those) and 15 minutes and I have 2 new fuel doors and mounts for my project.
Hope this info helps someone.
Terry
thesnake
Terry,
Thank You for the info. I just bought a 77 that has an aftermarket quarter panel with a single hole for the rear tank. This truck won't be a restoration, however, I may now try to include the fuel doors.
John
Apogee
Tangent, OR
Terry,
John
If you do, I'd suggest moving them up and out to better accommodate cutouts if that's a possibility in the future. I've got a '77 EB and a couple of '77 pickups, and I do believe the fuel doors are the only common parts between the two rigs.
tsmustangs
tsmustangs
All Over
I think Apogee is correct. I searched for a long time to try and find ones that matched. Got lucky and found the 78-79 ones. I didn't know the 77 trucks used the same door. But always good info
Terry
FJB
I did the same thing a few years ago. Found some off of a pickup at the u pull it. Only I didn't have a generator and a sawzall. I wound up using a broken hack saw blade to cut them out in the rain. They only charged me
$5. Great junk yard memories.
