Installing a front flat glass..
Pa PITT
Stephenville TEXAS
...Ok Guys give me a hand here ..
One of our members here PM'D me and ask how to install a front new flat glass ..I've done several fronts and backs through my years but felt I might be a little Rusty ...So some of you can add your tricks .
....New Glass IMHO want break like used glass and I've never had to be to careful with it ...Get one of your trusting buddies ...Not the one that comes over and says OK i'VE GOT 15 MINUTES TO HELP ..send that guy home Your wife is better help than HIM...
........Get a new gasket it may cost more than the glass But a new gasket is best .. Set it out of the box in the sun if you can find any these days..
After it is warm put it around the glass ..If you glass has square corners and your gasket has round ones ..SEND it back and order one from another vendor ..Guys help me out here ...WHO HAS THE BEST ONE ...I got one that fit like a glove and one that didn't..
....Next I put GOJO on the part of the gasket that is going to have to do the curling under ..the bending and flexing ..Not in the groove the glass sets in but the grove that goes over the window shield frame ..GOJO IN THAT GROOVE and then I use a nylon rope get 1/4 inch rope and next size up 3/8 is going to be too large ...If there is one between 1/4 and 3/8 get it if not then forget the 3/8 unless you have a 2nd use for 20 ft of 3/8.
.... Now I put the 1/4 rope in the groove around the outside of the Rubber gasket ..I prefer to have about 3 ft of tag ends in the top of the glass ..At this point it doesn't have to be all that tight ..Just in the groove ...Get all the screw drivers NO.1 AND 2 phillips and A couple of flats also ...Any other hook ends hand dent pullers ..Throw all those in the floor for added insurance ..You shouldn't need them but if you don't have them out you'll need 1/2 a dozen ..
...Put the gasket around the glass then the rope in the other groove and now set the gasket on the window frame try to center it up to start with ...Just save some fretting at the end.. With your finger since you bought a new gasket start working the gasket over the frame lip starting at on bottom corner ..Keep the rope snoog '' almost tight just don't let it fall out '' If it does then put it back in ..I believe your working on the inside ..The out side will almost take care of itself ..You can now start pulling the rope out of the groove making the gasket lip curl under and over in the inside of the Bronco frame ..Holding onto the 2nd end don't let it slip ..PULL on the 1st end work your way around the window frame and glass ...If it hangs up and try's to cut you new gasket then your rope is not big enough ..But here's where a lot of GOJO Comes in handy ..Also here's where you can pick up one of the NO.2 in the floor and work through the problem ..Pull your rope on around wastch your corners ..Pull the rope around that last corner you may need a 2nd or 3rd helper on the out side pushing in a little ..
.......On your 1st glass install it would be nice to have 3 people 2 inside and one on the outside ..All of you need to be able to work slowly and say stop and come look at this ..So we're all on the same page....
........AFTER it's in just massage the gasket get it down inside and out ..Now the GoJo is a good cleaner so it easy to clean up you mess ...
.........AT about this point your just about on your on ...and By the way It's sure to leak ..It's a BRONCO.....
...................Can anyone else add to this ..Feel FREE to say I do it totally different... This should save several guys and install ...When I did mine the 2nd gasket cost more than my glass... But I still had less than $100.00 IN my front glass...
........I Took a flat glass out of the back of my dodge truck ..Back when I was single at a motel one morning with only 2 limbs I cut off a tree ..Got my keys I'd locked in the truck over night ..That only took me about 15 minutes
...Most of that was with my fingers ...PS she helped with her head ducked.....
PEELDOG
if I can do it anyone can.use 1/4 clothsline to open rubber seal as u put pressure on glass pull string.real easy.
rekoj71
The profesional shops pretty much do it the same way. I watched them once on another car of mine and thats how I learned. It works for flat or curved, side and front. I just did my windshield with just the help of my 7 year old son. I had some 3/16 rope handy and used it. I like your gojo idea, I did mine dry and only used a screw driver a little at the corners to help the rope around them. I used to have a ford escort that I used to be able to pull the rear quarter glass out of if I locked the keys in, and I kept some rope in the car to put it back in with, but that glass was small enough I could reach both sides of it at the same time.
phred
Earth
papitt your post is as clear as I have seen. All the glass in a bronco goes in the same way. I've been lucky none of my glass leaks but the tail gate, that another story!
broncotime
Grapevine, Texas
It's a 1 or 2 person job max. More than 2 and you get too many people inside a small space. I used regular dish soap to ensure the cord was slippery. The whole process is very easy.
