I've been struggling to get a Magnaflow exhaust installed on my '77 Bronco (https://www.magnaflow.com/products/15344-magnaflow-1966-1977-ford-bronco-street-series-crossmember-back-performance-exhaust-system). I think the culprit might be that my long tube headers sit too low and I can't get the cross member to fit around the transmission correctly. As you can see in the photos, I had to use a flex pipe and adapters to get the cross member to fit, but it wasn't sitting correctly. I've tried using some s-pipe adapters to get the cross member higher but that didn't work.
Before I called a shop, I figured I'd check with the forum to see if anyone else went through the same thing and if I would need to use different headers, which might cost less than bringing the Bronco to a shop, or if it is something else. I can provide more photos if it is helpful. Thank you, as always.
