installing a nv3550 in the 77
blazinchuck
got my 5 speed today, gonna begin the swap after work today. few thoughts...
Ive had this 5.0 w/np435 in my rock crawler" fat bottom girl". right now i have the 5.0 in the 77 w/C4. Im planning to reuse the flywheel from the np435(I was told I could use it) it was new when i installed the np435. Im curious if I can still use the pilot bushing that was installed at that time? does the 3550 have the same size shaft for the pilot?
also, im not planning the install a body lift at this time. funds, time crunch,etc...so i know i will have to do some floor work to make this happen. I already have that bracket for a clutch assembly that converts the 5.0 block to older clutch style. Im planning for 4.56 gears...but the funds wont allow that at this time. this is also my daily driver, so my buddy Chuzie has loaned me his bronco while he's outa town so i wont be without a driver.
attachment.php
73stallion
Eugene, OR
no, the NV3550 pilot bushing is a different size, as is the splines for the clutch disc. what gears and tires do you have now? also there's a place out here in huntington beach who can sell you parts to make a 2 piece pilot roller bearing, can give you the number if you want. i'm eventually gonna pull my trans back out and do the roller rather than the brass bushing.
blazinchuck
blazinchuck
i still have another pilot roller bearing from a 92 f150 4 or 5 speed...guess thats not the same either eh?
is there a stock pilot bushing that does fit? ie...jeep,ford,chevy,etc?
blazinchuck
blazinchuck
BTT, i need a pilot bearing or bushing. i was told this is OD.1.377/ID.750/length.500
any factory vehicle applications use this same bearing? I guess i will have to call AA
blazinchuck
blazinchuck
well, got the crate unpacked(new tranny and stuff) removed the drive shafts,exhaust,and C4 last night. Today I will clean those parts up so I can have my C4 ready to ship back out. ran into a small problem...the guy I got this from didnt send the pilot bushing/bearing...this is a special bearing with a OD 1.377 x .750 ID x .500 length. cant find any bearing like this round here and not really interested in finding a machine shop to make a bushing. couple pics
EDIT: bearing distributors just called, they have some kind of bearing...going to check it out now
EDIT: well, i went to look at the bearing...POS alum housing, rough ground bearings...low RPM. no good, back to looking for the right bearing
Izzy
Texas
The timing of this may not help but Wild Horses has the pilot bushing you need. It's very small so maybe they could overnight it to you for a fair price.
blazinchuck
blazinchuck
thanks Izzy...the guy that im swapping with is overnighting the bushing...he just forgot to send it. so hopefully that will be here soon. guess ill clean everything up that is getting shipped to him, make the mods to the tunnel so this 5 speed will fit
Izzy
Texas
good luck man. if you need anything. hollar. I did this swap last year but so have several others on here. It's a fun tranny for sure.
blazinchuck
blazinchuck
What clutch are you going to run?
not sure, this was an installed kit with "about 1500 miles" on tranny and clutch ...the clutch looks new, so does the pressure plate...but i didnt see any names or anything. im sure this was a complete kit from a vendor...so whatever they would use is probably what this is. the shifter resembles TBP unless others use that "D" shaped knob
blazinchuck
blazinchuck
ok, well yesterday didnt go as planned! I got off work early so I could get a big jump on things. 1st thing i noticed was the broken input shaft bearing retainer plate...the sleeve for the throw out bearing was broken off and laying on the input shaft. Began calling every where for one and found one at a local dodge dealer....$109!!! My buddy Jonathon works there and hooked me up with a discount~$71, plus 3 quarts of special tranny fluid $20 each~got it for $13 ea.
once i got home and compared the 2 sleeves, i could see the broken sleeve was paper thin(completely worn out). this meant the input was walking around, so i checked the pilot bushing and found the I.D. was .825"! its supposed to be .750-.755. Now i had to find another bushing, but everyone that had one was in California. so i went and bought a stock ford bushing and had a local machine shop bore the inside to .755 for a perfect fit, he also had to remove a couple thousand off the outside to a 1.377(was 1.381)
got the dust shield,fly wheel and clutch assembly installed. installed the bell housing and clutch assembly...no pedals yet.
cut the floor support out(this was recommended since i didnt have a 1'body lift) that gave me some more room, so i installed the tranny(no D20). already the tranny is touching the floor! even worst...i started to install the crossmember...but it needs to go UP 1.5" and the tranny is still touching the floor! a while back i installed my monster motor mounts...i think if i swap those for stock, that will allow me to drop the tranny some and go up with the crossmember...I HOPE! so today, i will try to get stock mounts, and bolt the crossmember in..then D20 and pedals..FAWK im tired of deadends!!!
blubuckaroo
Grease Monkey
Ridgefield WA
Makes you wonder if the PO left the piolot bushing out. Are you just going to assume that the transmission input bearing is still ok? Looks like it took a heck of a beating.
blazinchuck
blazinchuck
that crossed my mind...however it looked ok(very clean like new) and i didnt feel any excessive play in that bearing. plus its installed and i aint removing the tranny for it now lol
also the pilot bushing was installed...it just not the right inside diam. AA seemed ton think it might been the wrong bushing causing the slop...oh well, its as right as i can make it now...we'll see
blazinchuck
blazinchuck
anyone know how much longer/shorter the nv3550/D20 compared to the C4/D20? i prefer no surprises...hoping the drive shafts will still work. for some reason back in the day, i seem to remember when i swap a C4 for a np435...it was a lil longer and i had to swap out the front/rear slip yokes to make the shafts the right length. im thinking this will be about the same thing since the vn3550 should be within 1/4" on a 3 or 4 speed tranny
any ideas guys?
blazinchuck
blazinchuck
IT DRIVES! got it going yesterday at 5:30.
lets see...after the big pilot bushing,input shaft bearing retainer episode the other day, i decided to work on swapping the pedal assembly. thursday night i saw that the pedal assem. i got with the tranny was missing the stud on the brake pedal(this is what the brake push rod and brake light switch attach too). so friday i almost went to LKQ(local pull yard) to start looking for a brake lever from another clutch assem...but i decided against it(tired of going everywhere and buying everything to make this work). so i reused my auto brake pedal and cut it to the right size as the clutch brake pedal. got looking right and installed a pedal cover i had laying around.
had the remove the steering column to get the pedal assem out(i think it would have been easier and faster pulling the pedal shaft out instead of the whole assembly-not sure if it would slide out...but looks like it)
got the pedals all done, time to work on the exhaust...
i was really worried the dual exhaust i just finshed a couple weeks back would not work, but after measuring and checking...looked like it would work. had to the front long sections and add slip joints and band clamps to fit it all in. got the drive shafts installed(no problems there), took care of the 2 neutral safety wires(from the C4), and capped the vacuum line for the C4.
today i had to redo the top of the shifter tunnel. didnt want to weld another one in place, so i made a removable cover. reused the toyota shifter boot from a previous project. havent cut a hole for the tcase yet. i just bought a set of JBFab twin sticks a month ago...so Jon was nice enough to offer me ship my old sticks back and he would swap them for the new twins that are made for the nv3550. once they come in..ill measure where the hole needs to be. all in all...it drove great last night...no real issues. shifts very nice. really wish i had installed a new throwout bearing. its ok, but wish i did...(oh well)
i did notice after my drive last night, i lost a nut from one of the 2 bolts that hold the trans mount to the cross member! that was the only part that was still bolted together when i got everything...and for some dumb reasom, i didnt check it. anyway, had to install a new 7/16th nut and all is good.
here are some pics...
904Bronco
San Martin, CA
Yeap, shaft pulls out, remove the spacer and install the clutch pedal...
What is the application for that shifter boot in the above picture?
blazinchuck
blazinchuck
haha...one of my buddy's in too toyota 4x4's. i saw his 5sp shifter boot and thought it would work on my last project bronco. it had a 5.0/np435. it worked great and i found it the other day, thought it might work again...sho nuff;) i like it.
it should be any yota truck/4runner 5speed;D
