- Jan 6, 2009
- 239
So, did they change the design of the lines? There is no way the lines I received would go "over" the trans crossmember. In fact, just before getting to the crossmember mine drop about 2 inches. They are nice and tight under it, but there is no way mine would fit on top of it.
I have BCB efi tank and the pre bent efi lines. I struggled all day and thought I had the wrong lines. Seems everyone has the same problems I did. The back half from the tank fit great, the front half I had to tweak almost to the point of throwing them in the trash I was so mad.I did not know if they went above or below the crossmember they were bent as if they should go straight through the crossmember. I finally tweaked them to go over but it was almost impossible to line everything up after that. The problem is the 8" piece that gives you the option of running saddle tanks, it goes over the crossmember and is hard to get together and I had to take mine apart a couple of times to get it not to leak.If they eliminated this section and just pre bent the lines over the crossmember with no saddle tank option it would have been fine I think. As usual I thought I was doing something wrong or just got ones that weren't bent right so I just complained to myself instead of calling BCB.;D
