Hey Guys,
Working on installing my new cam, Crane 444211 and springs 44308 (Didn't know when I ordered them you could get it as a set, 444212). Anyways, I have a few questions regarding the installation. The current cam is a FMS E303 with roller rockers, and shims below the springs. So my assumptions, correct me if I'm wrong, are:
1. You have to remove lifters (and, therefore, the intake manifold) to remove/install a cam.
2. The valve springs can be removed and installed by pressurizing the cylinder, I just need the spring compressing tool.
My questions are:
1. Those of you with the Crane springs, did you require valve spring shims? The installed height of the crane springs (1.950) is .13 higher than the FMS spring spec (1.820). I will verify with a gauge, of course, but just curious if I should get a shim pack before I start...
2. Are roller rockers adjustable in height? On the enlongated nut that holds the rocker, there is a set screw that seems to lock in the final height of the assembly. Should this height change? I wouldn't think so because the same lifter, pushrod and valve are being used together. I would think that the zero lash condition would remain the same. I can readjust if needed.
3. When turning the cylinders with a socket attached to the cam bolt and the timing cover off I can hear a hissing noise coming from the oil pan. Does this indicate a bad piston ring seal, or would this be the normal location for decompression? I would expect the valve, but maybe not. If I try to rotate it fast, I can't, the pressure builds up easily. Guess I should just remove the plugs and not worry about it...%)
Thanks for the help!
Eric
My questions are:
Eric
