installing turn signals
Brian B
I'm installing turn signals in my 75. Tell me if this is correct gasket on front of the turn signal bucket then the pads then the lense and screw tight. The screws I am using barely screw through the hole but is still touching / scratching the paint is that correct. I'm using stainless steel sheet metal screws.
Pa PITT
Stephenville TEXAS
It's really been too many years since I did mine but as I remember mine also would not work with the gasket on so I believe I cheated and left the gaskets off.
jray
Pads next to the bucket, gasket, then lens. Just put some on our '72. Are your screws long enough?
Brian B
Brian B
The screws barely go through the back of the bucket but when you tighten the bucket down to the grill the screw tips scratch the paint. Is this normal or am I missing something?
