Installing ZF hydraulic line to master
marklc
I must be doing something wrong. Installing ZF clutch kit from BC Broncos and I cant get the line tied into the master cylinder. Does it just push in or am I missing some kind of retainer to hold it in? There is a small hole where it looks like something should be there right below where the line goes into cylinder. Maybe my kit is missing something?
Thanks,
nik
Corcoran, CA
Thanks,
There should be a small pin that goes in that hole and slides through a groove in the line you insert keeping it from pulling out.
RedLeg0811
Maltby, WA
The tube is held in by a roll pin that goes in that hole.You have to push it with a fair bit of force, but not too much. You can make sure it is in there by pulling back on the hose a little bit.
M
marklc
Thanks guys thats what I was thinking just wanted to be sure.
