I tested the IVR with a voltmeter and I was getting pulse of current every 10-12 seconds with it attached to the instrument cluster. I took it out and ran hooked it up straight to the battery. The same thing. The ground seems to be fine.
Sounds right. Ground seems to be working.
I talked to the vendor where I got it and I sent it in for a new one. The new one pulses every 2 seconds, which makes the fuel sending unit in particular go up and down every 2 seconds.
The fuel "sending unit"? Or the gauge itself? The gauge should not pulse, since the reaction is slowed down through dampening. If you're reading the pulse back at the sending unit at the tank, then ok, that sounds correct.
Can you tell just how much voltage you're seeing at each pulse's peak?
Two seconds sounds about right, but just curious as to what it's peaking at.
The others didn't get all the way up to where they should be. Any other thoughts other than another bad IVR?
You mean the gauges didn't read where you would expect? Or that the voltage readings at the back of the gauge didn't seem to match the output of the IVR?
Not much wire to get a voltage drop in, so if it is dropping, you've got a bad connection somewhere.
If the gauges aren't reading where you expect, perhaps the total output of the IVR is low? Do you have a digital or analog voltmeter?
Sorry that your question brings more questions, but "is a puzzlement", as they say.
