Interminent wiper & Centech
stevew
Elliston Montana
Does anyone have a link or diagram on how to wire an interminent wiper switch into a current Centech harness ? The only write up I found is pretty dated . Thanks
Crush
Greenbottom, WV
I had an old one too. But cant find it. If i remeber you need to run an exrtra wire up to the motor to make it work. Cant remeber which connection it is though
stevew
stevew
Elliston Montana
Justin , saw that in my search but that's an early Centech where you had to take the wiper motor apart & change something that I've gladly forgot once they eliminated that from the new harness . I'm still uncertain if the wiring lay out etc. is different now . Way too much work to have it go poof !
Oops , just saw Johnjohn's post .... So you do it just like in the tech write up & it's good to go ?
gr8scott
If i remember you need to run an extra wire up to the motor to make it work.
Strange. My Centech I installed some 14 years ago came with four motor wires, Red, White, Blue and Black,
which were the exact same wires coming off the motor. I didn't have to add a wire. My factory connector was long
gone, so I wired mine up with a Weather Pack connector. The pink wire should be purple.
