Is kick panel hole necessary?
Thaddeusrex
I’m rebuilding where the driver kick panel, A pillar, rocker, and floor meet. The kick panel has a 1 5/8” hole at the bottom. I don’t know what it is for. It is on replacement kick panels, but I’m just rebuilding these, not buying new. Is it necessary? I don’t want it if not necessary, this is a restomod, not concourse stock.
Thaddeusrex
Thaddeusrex
Thanks PCB, any idea what the big one is? I looked at my tear down photo log, and they weren’t being used.
PCB 4x4
Can't say I've seen the larger one on any of our builds.
Thaddeusrex
Thaddeusrex
Very interesting. Thanks James! They’re a gonner then. I’m curious how you know? That’s pretty obscure info.
jamesroney
Fremont, CA
Well, when I replaced my first kick panel, (made by myself) I used the hole to align the two pieces together, and spot welded that sandwich. Then I got this idea to pull the tub and media blast the frame. But there was no easy place to lift the tub, and I couldn't use a strap without a spreader since the outer rockers weren't there.
So I used a spreader and lifted the body with those two holes and a hoist. So I ASSUME that the factory did the same. I could be wrong. I guess my question would be: "where else could the factory lift a painted body?" After stamping, after weld, after paint, but before assembly. (Fenders on, hinges on, Doors off, aprons on, core support on, floors, rockers, quarters and bed on, windshield on)
So I don't actually KNOW...but I have a decent Guess.
Edit...(maybe they used those holes for lifting when the tub is inverted?)
I go to great pains to install the holes, and make the sandwich. It is worth pointing out that the reproduction kick panels (that I've installed) have the wrong size hole, and it's in the wrong place.
Thaddeusrex
Thaddeusrex
Oh, that changes things. This body is going to have to come on and off a couple times so I can complete the chassis welding once I verify ride height/level with body weight on. Also, I’m going to have the body and paint finished at a shop who might need to. If those are needed, maybe I should put them in.
You probably won’t be verifying ride height very accurately with just the body. If that’s what you meant.
It’s gotta be literally everything. From hardtop to bumpers, engine to interior. Is that how you’re gonna be removing the body? Or is it just the interim body only?
If body only, I wouldn’t put too much stock in the measured height.
Thaddeusrex
Thaddeusrex
Yes, I realize that. i know I have to pile everything on. Frankly, I don’t know how I’m going to do it yet. I really wanted to just finish weld the chassis and be done with it, but the Duff guys are super insistent that that would be a big mistake, so I'm trying to follow directions.
The alternative method to that, is to compress the suspension to the expected ride height, and lock it down. Work with everything from there while mocking things up. The body can come and go as needed at that point.
For example, if you’re going with a 3 1/2 inch lift, you can set the front suspension height at 10 1/2 to 11 inches between the top of the axle tube and the bottom of the frame rail.
In the rear you would do it 9 1/2 to 10.
The nice thing about doing it this way is you don’t even have to have the suspension installed completely. If it is, you can simply compress it with ratchet straps to the desired height.
If it’s not, you can weld or otherwise attach bars/tubes/blocks between the frame and axles to set the ride height solid while you work on the rest of the vehicle.
Thaddeusrex
Thaddeusrex
Yes, I did that, i built the chassis at the expected ride height with the numbers you mentioned too actually. Duff said I should still just tack weld the frame brackets, diff housing bracket, and spring retainers on though. Then, when I have the fully loaded truck sitting on the chassis, verify that its the right height and level, then remove the hole body, cut tack welds and adjust if necessary, and then make permanent welds. I sure don’t like it, but that’s what I’m doing. I don’t know how I’ll lift the body yet when I have the whole thing built and sitting on the chassis. That’s a year or two away btw.
