Whoaa
- Sep 26, 2014
- 1,059
77' w/ a Dana 44
Does this mount look correct, the angle look right? Is it bent outward?
The hole where the bolt goes through looks like its wallered out. I was thinking about welding some [thick] washers on each side of these wallered holes to square it back again. But if its bent, I think it'll just be easier/better/faster to replace the whole mount. Suggestions?
What about the goober plate cob welded on the side of it.....this can't be factory, is it?
I going up 5 1/2" on the suspension and have a dandy WH trac bar riser fitted, and getting ready to weld to the front diff housing.
If the frame side of this mount is wrong, now is the time for me to fix it. Just cut this old one off, weld a stock trac bar frame mount back on the same location? Add some little triangle shaped gussets to the side of the mount for strenght?
thanks guys!
thanks guys!
