You need to:
It can all be done without removing the differential housing from the vehicle.
I wouldn’t worry about how it happened if you didn’t go in deep water. I’d just use 4wd a few times a year and get a good coating of oil on the inside. That will keep it looking like new in SoCal.
- Remove wheels, hubs, axles, and tie rod
- Shove a towel between the pinion and ring gears, and then turn the gears. This will pop out the differential. Keep the shims on either side in order.
- I would remove the pinion to keep rust debris off it
- Get a brass wire wheel on an angle grinder or drill and go to town on the inside of the case. Don’t hit the machined surfaces.
- I’d probably hose it out really good to remove all debris. Dry with a towel and compressed air. Spray liberally with WD-40.
- Inspect the ARB and clean the ARB. Replace seals and bearings as required. I’d probably toss the whole unit if the seal surfaces were damaged enough to cause air leaks.
- Reassemble
