Its Roller Time!!!
broncoitis
I am switching my motor to a Roller 302! Although still a 302 it will be a much better motor than the 302 that is currently in the bronco. I think that the biggest obstacle that I am gonna have is gonna be the harmonic balancer.
I believe that I am going to need a 50 oz external balancer? The motor that is gonna be replacing the current motor is from an 89 Mustang. Is that correct? Also, because I am running the Explorer Serpentine setup the timing marks have to be on the passenger side of the damper preferably. Could I also use a 97 explorer 302 balancer with no ill effects on this motor?
blubuckaroo
Grease Monkey
Ridgefield WA
The 5.0 isn't all improvements. Rear main seal replacement will now require disassembly of your power train. I think the old Ford guys had it right.
broncoitis
broncoitis
Ah come on, why ya gotta rain on my parade! LOL! I guess but hopefully that wont be an issue for a LONG TIME! ;D
garberz
Bronco Influencer
Conejo Valley, Ca.
The 89' motor uses the 50oz balancer. If your going to run the Explorer serp, then you'll need to use the Explorer timing cover and the Explorer damper. All that stuff is compatible, you're good to go. You'll need to address your clutch linkage set up. The new motor won't have the mounts for the equalizer bracket.
Mark
Viperwolf1
electron whisperer
And you'll need a 50 oz-in flywheel or flexplate.
broncoitis
broncoitis
The 89' motor uses the 50oz balancer. The new motor won't have the mounts for the equalizer bracket.
Ok, I will have to see if I can dig up my explorer balancer! I know that I have it somewhere! The brackets for the clutch linkage will definitely be a problem to think about. Hadn't even thought about that issue! I honestly have no problem with the mechanical linkage setup at all. it is simple and works well I think. Hmmmmm!
Forgot about the flywheel as well! This is probably a dumb question but how many teeth are the ones in the Bronco? I would think that I need one with that tooth count to work with the current starter and bellhousing that I have?
This is why this site is awesome. Y'all always point out stuff that is being overlooked and these were both overlooked for sure. Probably the biggest oversight being the clutch linkage mounts on the block that won't be there. %)
Thanks for the heads up on this stuff for sure! Gonna have to wrap my head around this for sure! ?:?
This is a fairly simple and straightforward fix. http://www.wildhorses4x4.com/product/EFI_Clutch_Equalizer_Conversion_Bracket
You can drill your own hole in the block if it's got the boss in the casting where the hole used to be, or you could fab up some other sort of bracketry.
Or you could simply bolt it on with the remaining bolt still in the bell housing and get away with it most of the time. But the aftermarket bracket is just one more level of security.
Correct. 164 tooth 50 oz flywheel (http://www.wildhorses4x4.com/product/Flywheel_Late_Model_50oz_164tooth) for late model trucks.
Luckily, not a huge deal and many others have dealt with it before. So there's good info out there.
broncoitis
broncoitis
Thanks Paul! I honestly hadn't even looked at the situation regarding the linkage under there. Its good to know that there is a solution to use the original clutch setup and not have to worry about setting up a hydraulic system. This is a good start to today! ;D
broncosbybart
Quick tip:
Check the clearance between the bolt head on the cam gear and Explorer timing cover. It is real close. If in doubt remove the cam gear bolt and grind the head of the bolt down some.
It isn't a hard swap. Good luck!
blubuckaroo
Grease Monkey
Ridgefield WA
Oh, don't let me bother you. I'm just an old guy with an old guy's opinions. One piece seals were one of the lessons our American auto manufacturers learned from the Japanese auto manufacturers. They work great. As long as you drive it in straight, it should last a long time.;)
