I've had a handful of different failures (along several different Fords with the same basic IVR)
Out of calibration is probably the most common. All the gauges (and for further discussion, this means all that are connected to the IVR and only the ones connected to the IVR) read high or low.
Completely failed, the contacts fail to connect anymore, all the gauges read low.
Loss of ground, the contacts stay shut and the gauges peg.
The weirdest one was on my BroncoII. When exiting the freeway after a long drive and coming to a stop, the gauges would peg. Tap the cluster aggressively and they returned to normal. Not all the time, once every couple months? Or twice a week. Freaked me out as the temp gauge would peg coming off the highway but realized it was the IVR as the gas tank suddenly went full at the same time. Never figured that one out.
Todd, it does sound like the contacts inside the IVR are finally failing. Considering that over the decades they have cycled a few billion times.
For those that want a basic IVR class on how they work. It is a bi-metalic spring and a heating element. Just like what is in the rest of the gauges. As the heater warms the spring, it flexes. In the case of the IVR it doesn't move a needle that you can see. It moves a set of electrical contacts. When it is warmed enough, the contacts open. That turns off the power to itself as well as the rest of the gauges. Now the heating element and spring cool. The spring returns the contacts to closed and the heating starts over again. You can often see this in the gauges that swing slightly during operation. I see it most at key on with a full tank of gas. The gauge rises quickly as there is a long initial heating of the cold IVR before it stabalizes into its cycling. The gas gauge has a bit more heating to do and it will swing up to maybe 3/4 where it will pause for a moment as the IVR starts cycling. The next IVR cycle will heat the fuel gauge a little more and bring it up to 7/8. A couple more cycles and it will finally show a full tank. But it is notchy to get there. The factory style IVR is also temperature compensating. On a really cold day, it is cold as well as the gauges. It spends more time in the heating cycle due to thermal losses of being cold. The guages are also cold, so the added on cycle time will add more heat to the gauges as well. that should make them read high. But they are in the same cold as the IVR, loosing the same heat as the IVR, and that brings them down. They counter each other and result in a pretty accurate (for what these gauges are) reading that is stable in the cold. Same thing happens in the heat, just less cycle time. Again, temperature compensating. Something the solid state IVR just can't do.
Almost forgot an important part. The IVR ground. That grounds the heating element. If the IVR isn't grounded, the heater won't heat, the contacts won't cycle open. This will just send a continous battery voltage to the gauges. And they all read high. Same thing happens if the contacts weld, or the heating element burns out.
This cycling can confuse a lot of people. They often see they spec that the gauges run on 5V. And that is also what the solid state IVR is set to provide. But that spec is deceptive. It is about 5V average. You get 12V for a couple seconds, then 0V for several seconds. Then it repeats. If you average the time on and the time off, about 5V, depending on temp.
