NC-Fordguy
Guys
I'm helping out a friend with her 69 bronco
Right now, the gas guage is not working(reading E) even though there is gas in it
The Temp guage is reading only 120 degrees after a long drive(100 degrees outside)
Both the ALT guage and the oil pressure guage is erratic.
The Voltage regulater next to the battery was reading between 15-16 volts under load so it was replaced. Reading is normal with new regulater now
Question I have, do you all think that the excessive voltage may have damaged the IVR as I find it hard to beleive all 4 guages/sending units would have gone bad at the same time.
Also is there a way to test the IVR to verify??
