Jamey's Build Thread
KyleQ
Looking good - what are you guys doing for bump stops with the Cage arms?
SpareParts
Nothing for bump stops for now, Jamey doesn't rub with his 36's. I cleared the 37" Boggers pretty easily and nothing bottoms out. I should have my bead locks today, after I get them and my 40's installed we will see how much I have to limit my travel.
David
KyleQ
Nothing for bump stops for now, Jamey doen't rub with his 36's. I cleared the 37" Boggers pretty easily and nothing bottoms out. I should have my bead locks today, after I get them and my 40's installed we will see how much I have to limit my travel.
David
Ok - lol, I'm not worried about my tires hitting the body, I'm worried about the trackbar smashing into the oil pan or my hydro ram :-X
Buldozer
Bronco Virtuoso
God's Country
Man cutting & grinding those run-flats down was one hell of a job! :eek: Now I can see what you were telling me Jamey. You guys make a good tag-team....well I guess it's not tag-team, but whatever you call three with David's helper pitching in! Now I see why he got to go to SMORR.....he did a lot of helping on your rigs! :cool: Good job guys, all of you.
goneballistic
goneballistic
Washington, MO
well now that I broke my Steering box. I can go ahead a fix it as well. I have a ram assist sitting in a box, just need to get it all on. I am going to send the box out to get it fixed and drilled, then when it comes back ill get the ram on it. We have a mud bash coming up this weekend(June 6th) so I put a spare box on it that has been borrowed by david from another guy, (who seems to not be in a hurry to get it back).. The roll cage will be designed and put in the week after that. I bought some 39.5 Iroks, but need the body lift on it first. Ummm what else... 2 1/2 tons and 49" iroks??? No just kidding!!:eek: Hopefully I might be able to get some new paint on it before OCBR.
It was nice to meet your rig in person Jamey, it sure did great out on the trail ;D
And I was just wondering, what have you got up your sleeve from here %)
astark
Bronco God
Well that is going to be one capable OCBR rig, with or without the new paint. I was over at the Arkansas thread looking at the pics there and that was some spooky stuff you were doing, especially with the jeeps on their sides. But backwards without steering :eek:
And just wondering, did you guys do that trail again we dedicated to Michael.
Buldozer
Bronco Virtuoso
God's Country
Man your rig is going to be rockin by OCBR if you keep working on it. I figured you would go full hydro, but the combo is a little safer....not that safety ever occurred to you. Were are the pics of David's pit bull 40's? Been waiting for those to show up on here somewhere.....
Rick
goneballistic
goneballistic
Washington, MO
Yeah Alan, we did Michaels trail. I told them all about it and how we had a good time getting your rig through it. They (4 Jeeps Cherokees) loved the trail! You and I seen it dry... well i seen it wet!!! Wow what an awesome trail! Its getting dug out and the holes are deeper now. I think with it wet its atleast a 4.
SpareParts
Rick
I need to do that, I've been driving them on the street. Still a couple of issues to work out. I have been busy working on other stuff in the shop. I found my week link already with them, I exploded my front one ton drive shaft. The neapco ujoint and the h-block exlpoded when I started wheel hopping a little and couldn't let out quick enough.
We'll have to see how I'm going to upgrade it. ;D
David
goneballistic
goneballistic
Washington, MO
Here is some pics of my H1 Wheels while in the process of welding the new centers in them. I didnt realize i never put these pics on here. I know David put some up on here. The Plasma cutters quit working, so Nathan had one of his workers cut them out with the cutting torch. I had alot of grinding to do, but with what little money I have in these wheels it was well worth it.
goneballistic
goneballistic
Washington, MO
What you talkin about Rick? You already seen them in action at Howiepolloza. Ill figure something out on getting that Tuesday off. I ran into to a health issue(bone tumor in lower right femur) and trying to figure out if I can postpone surgery till November. If I cant then ill wont be there at all. And not its no Cancer. Its not a solid tumor.
Sweet! Can't wait to see these in action at OCBR, you did figure out how to get off on Tuesday didn't you?:?
allenfahey
I too did the recentered H1 rims and used the pressed centers from MADMAC on Pirate. I also cut down the runflats like you did. I'm probably late with this hint but I bolted the 2 halfs together and layed them on the ground. I then used an air hammer to remove the flat spots in the ribs. Then used the sawzall on the webs that were left.
Buldozer
Bronco Virtuoso
God's Country
Geez, I always knew you had a heavy right foot, but had no idea what was causing it?:? ....seriously, I hope you come out ok with that. Even though it is not cancer (which is great!) that sounds serious for sure. If they can just wait till October you will have a much quicker recovery I am just sure!;)
goneballistic
goneballistic
Washington, MO
Yeah if they can wait till Oct. for sure. Because it will take longer for it to heal when Im out on the trail at OCBR with crutches.
goneballistic
goneballistic
Washington, MO
So I haven't put no new pics up since Ive done a bunch more work to it. So here are a few more pics.
I cut off the rockers and made me some 2 x 6 1/4" thick sliders. welded the ends and tacked them on, then had Nathan weld them on. Hes a better welder then I am! LOL
goneballistic
goneballistic
Washington, MO
I also put Ram assist on it as well, but didnt take no pics of that project. I didnt drill and tap my box like everyone else does. I drilled and tapped the top cap where the adjuster is and then used an EMS.com front cap. I bought some Hydro lines and connectors from Orschelns. and I already had a AGR Rock ram. So I only have alittle over $250 in the whole thing. And everything works great!
goneballistic
goneballistic
Washington, MO
I also started sanding on and taking apart the whole thing. I planned on having it painted before O.C.B.R. 09. So I had alot of work to do.
goneballistic
goneballistic
Washington, MO
After I had it all sanded and ready to paint I taped everything off and started shooting the primer.
